Las Pauls & 1Meg Pots ?
ChuckLogan
Post by ChuckLogan » Tue Nov 28, 2006 5:17 pm
Hey there,
I was checking a website for a vendor in LA and they were saying that installing 1 meg volume pots can greatly improve the "openness" of the guitar.
Does anyone have experience with this ?
45auto
Post by 45auto » Wed Dec 27, 2006 3:40 pm
i've seen some talk about different values altering the "tone". i always thought using the smallest value possible to oppose the pickup would give you the best taper? i use 250k's when i can.
rockstah
Post by rockstah » Wed Dec 27, 2006 3:56 pm
well 250k in the volume position is darker then 500k pot which is brighter and hotter. 1 meg for a volume? think tele baby.
Post by Flames1950 » Wed Dec 27, 2006 4:07 pm
The thinking is, the bigger the pot the more resistance to ground when the pot is wide open, so less signal leaks away -- which is most apparent in the highs.
JD
Post by JD » Wed Dec 27, 2006 4:24 pm
Problem with going from a 500K to 1M is there is a huge sweep of the pot that has really no effect, and it is more sensitive to small changes as there is more resistance (~2x) per linear distance.
JeffG.
Post by JeffG. » Fri Dec 29, 2006 9:58 am
I just put a 1 meg on my Gibson 500T last weekend. Factory was a 300k. Using it with a Tonestyler and I can roll off the highs with that. I like it. Not sure I would always do it, but for now its cool.
