Metro Jam
- 45auto
how do ya get it to play? i just get a white screen that says:
This window starts the SoundClick player. If you have enabled a pop-up blocker, you can click the link here: play the song (no worky...)
- St August
The new guys that are joining can get the file from here..
http://www.yousendit.com/transfer.php?a ... 1A0E4B3D4D
go back and read the previous threads to get up to speed
- St August
- tonejones
Recorded tonight.....St August wrote:Well does anyone got anything finished.. If ya do Im a waitin.....
Should have it to send to you (not my recorder) mon. or tues.
Gotta few warts on it, but I'm still trying to get used to playing thru a Marshall.
All things considered I'm happy with the track.
Here's the specs:
'69 circuit w heyboer PT, OEI OT, Sozo caps, PPIMV w/ no presence.
V1: RFT, V2 & V3 JJs still, also still JJ E34L power tubes
Schecter Tempest w/Highorders
TS-5 Soundtank (level 10, tone 0, dist. 5)
PPIMV 5
bass 5
mids 4
treble 5
channel 1 vol on 8
thru Avatar 212 w/Eminence v30s
Recorded with: BOSS 1600 & MXL large diaphragm condenser (nice budget mic for recording)
BTW....,
FYI: first solo is an attempt to bring the 80s chops back up to snuff
while the second I used my coil tap and went a more bluesy route......
Also I did hold/sustain single notes past the cutoff points, as I thought they might be a nice option for layering while fading out from one solo to the next......
Let's get going, 'cause there's too much music, too little time!!!!
- St August
- Flames1950
Seemed like enough guys had signed on that maybe we didn't need another clip......but the Super PA is done
, so if I get a chance before you put it all together I'll do another take. I'm on vacation Labor Day week, so if it's not all wrapped up by then I should be able to find some time.
I'll start woodshedding more ideas in case I can pull another one out of the hat.
Cocked, locked and ready to rock....hehehehehe......
- St August
- 45auto
ok, i'm an idiot. how do we do this? do i just import this into cubase & record a lead track on any of the "verses" then send you the mp3 of just the lead track only? thanks brethren
- JimiJames
45auto wrote:ok, i'm an idiot. how do we do this? do i just import this into cubase & record a lead track on any of the "verses" then send you the mp3 of just the lead track only? thanks brethren
Like This My Good Man !
St August wrote:segment length
12 bars each cord pro gression as follows
F D( chugs)
F D
AFGA AFG
example
http://www.soundclick.com/util/getplaye ... 85901&q=hi
Once youve recorded a couple of the segments just send them to me and I'll insert them in the master track . remember I dont need the backing track just you segments...
Jimmie K.
- St August
But also send them with the backing track so I get a better idea where to insert... thanks....JimiJames wrote:45auto wrote:ok, i'm an idiot. how do we do this? do i just import this into cubase & record a lead track on any of the "verses" then send you the mp3 of just the lead track only? thanks brethren
F D( chugs)
F D
AFGA AFG
example
Jimmie K.
Jimi check your PM's
- 45auto
where & how are we sending these files dudes?
- St August
- 45auto
that is correct sir, how long 'til we hear the final product? thanks again
- St August
well we got 6 solos in place but NitroLiq is going to due his over again, he wasnt happy with his tracks and there are still a lot of guys that still havent sent theres in. Ill be getting at least tonejones monday or tuesday so we'll see where it sets at the end of the week and see where were at then....
Also Nice riffage
Also Nice riffage
