Radio Spares De-Luxe replica coming soon.
- VelvetGeorge
- Site Owner
I've been keeping this under my hat until I knew there would be an absolutely world class output to offer.
Finally, thanks to a recently available type of steel and detailed first hand specs. There will be a new Metroamp transformer coming out soon.
No actual ETA yet. But I'll keep you posted.
- Guitar Adjuster
- VelvetGeorge
- Site Owner
- VelvetGeorge
- Site Owner
The specs are from the original Radio Spares De-Luxe output.
Multiple primaries:
6.6k, 8k, 9k and also ultra linear taps.
Multiple secondaries can be wired for output impedance.
There is a unique stack and silly amount of interleaving. Which makes it only doable by hand. So it's an expensive OT to produce.
Multiple primaries:
- Flames1950
- Brian Wallace
- Supporting Advertiser
- VelvetGeorge
- Site Owner
- Brian Wallace
Steel
Hey George,
Yes, Phil has mentioned the steel. I use the M6 right now for mine. I think an A/B comparison is in order. Hmmmmmmmmmmm
I'll get you some readings in the next couple of days.
- VelvetGeorge
- Site Owner
- Brian Wallace
I suppose this new tranny can handle a misload like the old ones and like germino's heyboer RS tranny? The bluesbreaker combo amps only had a 16 ohm output, but the speaker load was actually 8 ohms. This results in a thicker, more distorted sound than if you use a 16ohm load according to germino.
