blacklabel
Post by blacklabel » Sun Dec 08, 2024 3:09 pm
Hi guys, had you seen the original Marshall JMP 1959 #38 modded by Frank Levi for sale on Reverb?
it was sold
Living in Europe it was impossible for me to buy it, it was only pick up, so I asked for photos of the inside but I didn't receive any answers..
https://reverb.com/item/85610186-marsha ... 1972-black
https://reverb.com/shop/kyles-gear-outlet-1033/feedback#
itsneverloudenough
Post by itsneverloudenough » Thu Dec 19, 2024 1:39 pm
it was sold
Hi, sorry for the late reply (but please respond whenever you see this, no matter how much time has passed -no, not kidding). Unfortunately Reverb refuses to show me the listing, it just says "That listing sold. Check out the similar listings below.". And when I try to filter for Marshall amps via the "sold" filter, I can't find it. Do you know if I can get around that somehow? Perhaps if I made an account (don't know if you have one there)? Did you keep any pics of the listing, maybe?
Oh and by the way that #38 isn't a typo, right?...
blacklabel
Post by blacklabel » Sun Dec 22, 2024 12:17 pm
https://www.mediafire.com/folder/dhgo0k ... %2338_LEVI
#38 existed and of course like the 39 36 34, this one was also owned by SIR Marshall, of which Caswell first and Levi later, were 'simple' employees
itsneverloudenough
Post by itsneverloudenough » Mon Dec 23, 2024 7:45 am
Hi, yes I'm well aware, was just double-checking since I couldn't open the listing (issue rectified since, lol -but thanks for going thru the trouble to put those pics up!). In fact, I'm pretty sure that 1. there's a schematic for this exact amp right here (bottom of page -really makes me wonder how this amp, obviously still in SIR ownership back then but not in use, ended up in...Georgetown, Ohio(?), in a private seller's hands): https://web.archive.org/web/20060325014 ... 41274264/0 , and 2. based on some people who'd been in touch with Frank Levi (such as bennyx, his post is somewhere on previous pages here), this being a "Mk7" mod (the "holy grail" series was Mk5, IIRC), it should not be the same sound as the AFD/UYI type mods. Which in all likelihood makes this a cool find, but "expensive by association" only, and the seller description misleading...though judging by how many people were utterly convinced they had "the sound" with the Caswell mod, only for the Levi/#34 mod variations to emerge later, I'm sure the buyer is himself utterly convinced he has "the toans"...or about to convince other people his "AFD-inspired clone" does...
On a tangential note, the few people ever associated with SIR and those amps are leaving us at an alarming rate...*almost* everyone I've tried getting in touch with, including the OP on the Hoffman Amps thread, are long gone...and most of them too young...
dukeamps
Post by dukeamps » Sun Dec 29, 2024 8:33 am
snakepit86
Post by snakepit86 » Tue Jan 07, 2025 11:39 am
dukeamps
Post by dukeamps » Tue Jan 07, 2025 2:20 pm
dukeamps
Post by dukeamps » Sun Jan 12, 2025 3:18 am
reychapa
Post by reychapa » Mon Jan 27, 2025 4:17 pm
Hi
I think i found it :toast:
https://www.youtube.com/shorts/Yq99RcOt9Vw
Este es!, muy bueno Gonza.. :hairband:
snakepit86
Post by snakepit86 » Tue Feb 11, 2025 4:35 pm
Gracias Rey!
Por fin despues de 15 años! jajaja
snakepit86
Post by snakepit86 » Tue Feb 11, 2025 4:36 pm
Hi
Gracias Rey! por fin, ahora puedo disfrutar de tocar!
dukeamps
Post by dukeamps » Wed Feb 19, 2025 8:56 am
BRMSlash
Post by BRMSlash » Fri Feb 21, 2025 1:26 am
Sounding great everyone!
I've finally got back into things after a long break.
I've changed back to Sozo NexGen's, 1k8/22u first stage, moved 150k dropper to the 2nd stage volume pot & tweaked the peakers. Moved the 4th stage cathode bypass cap to 3rd stage. Also reduced the voltage rating of the cathode bypasses to as low as available.
https://soundclick.com/share.cfm?id=14947816
Recorded with SM57 through UR-RT4 with transformer active & 40Hz high pass.
dukeamps
Post by dukeamps » Tue Feb 25, 2025 7:20 am
Unique
Post by Unique » Tue Feb 25, 2025 1:01 pm
Wow, this '69 mod' of yours sounds incredible! Well done.
