opinions on this tone please!
This is my first attempt ever on the VH-tone. What I did was plugging directly into my RI (at my normal settings)which went into hotplate at -4 into 2 cabs. I used my straight checkered and my '70 slant bass BW. The slant BW was miked right at the speaker cloth and the straight was miked from 3ft away. The slant BW is to the left and the straight is to the right in the mix. I used 2 sm57s for the recording, and my duesenberg V for the playing!
Oh, I forgot - I recorded and mixed this on my ZOOM MRS 1266.
Let me know what you think!
http://www.mp3lizard.com/download.cfm?id=19651
- rockstah
- Bainzy
It could be the mic that's 3ft away - the lower the frequency of the sound wave, the longer it takes to develop. Have a go at using 1 mic off axis (45 degrees) 1-3 inches away, that's my usual SM57 mic position so I'd be interested to hear how your amp sounds with it.
Shred Guitar
Shred Guitar
- mightymike
- Bainzy
possibly - it seems to add depth and power to the sound but it also makes it a bit distant sounding too. any chance you could cut another mix with just that channel?
Shred Guitar
Shred Guitar
- rockstah
Mike,mightymike wrote:Hey Mark how do you set up your mic(s), and what kind do you use.
sm57 pointed straight on - adjusted while i listen to it in head phones. i listen for the best balance between the high end of center of the cone to the bassy side of the paper. ends up being slightly off center. straight on off center of the dust cover.
Mark
- Guitar Adjuster
- Guitar Adjuster
- rockstah
more clips to come. i have had some stuff on my plate. but you know ill have more clips;)Guitar Adjuster wrote:Mike it sound great IMO.
Marc---
No recent clips? BTY--I got the teflon wire in, sweet, I tried to melt it with my soldering iron---no way, got so hot I had to hold it with my needle nose and it still did not melt.
Allen
i want some of that wire for sure - and the speaker box!
Mark
- Guitar Adjuster
