HOLY SHIT! OK, I'm gonna have to have some Armenian coffee and go back and read all that.
Starting with Chris. That dude is "THE MAN"! No doubt about it. I've had many conversations with him at this point and many of our chats are about shit outside of amps and tone. About 3 years ago, I was at work offshore and we had a 35KV transformer blow up. I was about 15 feet from it when it did. It was so loud, the shock wave about blew my hard hat off my head. I though my life was over, it scared me that much. He designs and builds shit like this, and even bigger. He talks about all the tension and stress he feels in the same way, when he does startups with some of his big ass projects. Stuff that will make you real dead, real quick. There should be no questioning or dismissal of his information in any way. "HE KNOWS HIS FUCKING BUISINESS". And he's far too engaged to be toying around with any bullshit rumors, mod theories or the like. He is not one to perpetuate shit that isn't either fact or personal experience, PERIOD. In fact, recently, he's the only guy who has been able to clearly explain the polarity/death cap concept on the Marshall's made for the U.S.from back in the day and I researched the shit out of that subject for almost a month. One e-mail from Chris and "BOOM" as you put it.
Anyway, more to come on that issue later.
I used his transformers in my new build and his PT has 100V, 120V, 220V, 230V and 240V primary options. Unlike the originals which were designed for 105V-110V's (U.S. option), I think using his PT with the 120V tap would be the equivalent of an original (like yours) with the variac at 110V's because Chris knows this and designs his stuff with this sort of knowledge. But I use a variac anyway so that I can ensure a true # regardless of where my power source is. It's a small one too, 5 amp. I'm going to buy another one and try the little stunt you talked about (Only calling it a stunt for humor. You know I love ya bro, no disrespect here). But I'm still not clear on the wire mapping. Seems like two ways this can be done.
1) The speaker out's tip and sleeve wire nutted to an AC plug that plugs into the blades of the variac and within the wire nuts are the tip and sleeve from the cab.
Or:
2) The tip wired in to one blade of the variac as sort of an "IN" while the other blade acts as an out for the tip to continue to the cab, while the sleeve leg runs straight from the amp to the cab.
Either way seems friggen nuts
but if Chris signs of on it, I trust it's good info.
