help clarifying vintage MXR 6 band EQs
jnew
Re: help clarifying vintage MXR 6 band EQs
Post by jnew » Sat Dec 21, 2013 3:06 pm
Hmm. The switch I have only has 6 little solder posts. Not 9 like that diagram. Will this not work even if it's not "True Bypass"? I can change it to the True Bypass later if I decide I really like it. My Epos-3 pre-amp build uses the same switch and I'm perfectly happy with it. Can we make it work? 8)
vh junkie
Post by vh junkie » Sat Dec 21, 2013 3:33 pm
The right (3) posts in the diagram are for the LED. You can leave that out. Are you using a footswitch, or just a DPDT toggle?
Here's a different way to wire it... input on the left, output on the right, 6band input top left, 6band input top right.
The bottom two lugs on the switch are junpered, but you cannot really see it because a wire is in the way
http://forum.metroamp.com/viewtopic.php ... 4&start=15
- Gunny Highway
jnew
Post by jnew » Sat Dec 21, 2013 3:37 pm
It's a stomp button. I have an LED on the other one so maybe LED can work?
vh junkie
Post by vh junkie » Sat Dec 21, 2013 4:24 pm
In that case, tie the two input wires, that are attached to the left side of the switch, together and hook them to the bottom center. Essentially eliminating the left side of the switch, using the center to switch the output only, and leaving the right side free to drive the LED.
- Gunny Highway
rgorke
Post by rgorke » Fri Jan 03, 2014 12:10 pm
So, back to the "did Ed use the MXR 6 band or not in the studio" discussion, here is a picture from the Zloz book. Right above (or to the left since the picture is sideways) of the #2 pedal. RIght by the Big Mac styrofoam container.
vanhalen5150
Post by vanhalen5150 » Fri Jan 03, 2014 2:03 pm
I thought was just a staged photo when they pulled all the gear from tour truck.
rgorke
Post by rgorke » Fri Jan 03, 2014 4:50 pm
vanhalen5150 wrote:I thought was just a staged photo when they pulled all the gear from tour truck.
If you were gonna stage a photo, would you put all that stuff...echoplex, Schaffer thingy, etc and hook it up and mic amps and drums. I bet it was staged in the sense of trash, etc. and having everyone pretend to sing and play. :shrug: I dunno
Fun to argue about though...
jnew
Post by jnew » Fri Jan 03, 2014 7:29 pm
Um, let's see here fellas, HE USED IT! [/b]
vanhalen5150
Post by vanhalen5150 » Sun Jan 05, 2014 4:34 am
I'm sure I read that Zloz staged that photo. To what extent I don't know. I dont think you'd never mic a cab that close to cymbals or a snare drum. At least from a recording sense you wouldn't.
rgalpin
Post by rgalpin » Thu Jan 16, 2014 1:02 pm
vanhalen5150 wrote:I'm sure I read that Zloz staged that photo. To what extent I don't know. I dont think you'd never mic a cab that close to cymbals or a snare drum. At least from a recording sense you wouldn't.
I used to think the same thing - but have since made recordings my self in similar setups and it's actually totally plausible:
http://www.soundclick.com/player/single ... i&newref=1" onclick="window.open(this.href);return false;
They may have just staged DLR's mic out there in the middle of that - shirley he would have been in an iso room even for scratch vocals.
Post by Tone Slinger » Thu Jan 16, 2014 1:09 pm
Nice track Rob ! Had a nice vibe to it, loved how you laid at the back of the beat :thumbsup:
rgalpin
Post by rgalpin » Thu Jan 16, 2014 1:19 pm
thanks TS! the Eventide makes you play different - as soon as you hear THAT sound you start channeling - :lol:
Post by Tone Slinger » Thu Jan 16, 2014 1:32 pm
Awesome feel in that solo :thumbsup: You milked it bro :thumbsup:
rgalpin
Post by rgalpin » Thu Jan 16, 2014 2:06 pm
hold on - let me listen to it again... yeah yer right!! oh - except right there... and there... it's not fun until you fall down. bliditty bliditty blip - bliditty bliditty blip - [stumble :peace: ] :D this was recorded in a basement with a simple mic setup on the drums and the guitar right there next to it. so, i can imagine that in a nice performance room with real acoustics, you could go at it like that and get something like what you hear on VH II. with vocals iso'd of course. just saying that MAYBE this is not a total zlozower setup so you can't discount anything you see laying around based on that.
Post by Tone Slinger » Thu Jan 16, 2014 2:17 pm
What gitfiddle was you 'a strummin' on that ?
