Recommend me a DMM
metalhead3ecr
Recommend me a DMM
Post by metalhead3ecr » Mon Mar 25, 2013 8:49 am
Would a Fluke 15B be a good one to start off?
http://www.ebay.com/itm/True-NEW-FLUKE- ... 4ab1580b60" onclick="window.open(this.href);return false;
YMI5150?
Re: Recommend me a DMM
Post by YMI5150? » Mon Mar 25, 2013 10:01 am
Yes. They make one that can measure capacitance which could come in handy but this is fine.
metalhead3ecr
Post by metalhead3ecr » Mon Mar 25, 2013 10:49 am
I thought this one could do that? it has the little capacitor symbol right? haha hmmm
Post by neikeel » Mon Mar 25, 2013 11:48 am
I have a Fluke 115. For me the best compromise for features and value for money. I also have an AVO Mk VIII and an LCR meter and access to a Megger. I am short of a decent cap tester.
That one you see in the add is a bit basic, IMO
For professional use an 87v is the biz but v expensive.
metalhead3ecr
Post by metalhead3ecr » Mon Mar 25, 2013 11:57 am
good info! Maybe I should specify my price range. nothing more than $120 shipped.
Post by neikeel » Tue Apr 09, 2013 11:53 am
What did you buy?
demonufo
Post by demonufo » Tue Apr 09, 2013 12:47 pm
neikeel wrote:I am short of a decent cap tester.
The best thing you could do for the money is look for an old Sprague Tel-Ohmike model, but in the past couple of years they've really dried up in the UK. Stuff like my Sencore LC-101 is a little unnecessary. The most important thing to test for is insulation resistance, and note how quickly they charge up, which the old Sprague units are perfect for (and other vintage capacitor analyzers to be fair, but at least the Sprague gives you reasonable results on all other settings too)
Unless anybody has any capacitors of unknown value, being able to test for capacitance is of limited value. They're usually within capacitance spec. even when completely knackered.
So I like purple, okay!!!!!!
Post by neikeel » Tue Apr 09, 2013 1:29 pm
That is useful - I will keep a look out.
demonufo wrote:Unless anybody has any capacitors of unknown value, being able to test for capacitance is of limited value. They're usually within capacitance spec. even when completely knackered.
Yes that is true, I do have an LCR and some facility on the Fluke but it is the leakage and ESR tests that I would like.
demonufo
Post by demonufo » Tue Apr 09, 2013 4:09 pm
neikeel wrote: Yes that is true, I do have an LCR and some facility on the Fluke but it is the leakage and ESR tests that I would like.
ESR test is useful if you have nothing else, but if you can measure leakage current it is excess to requirements. ESR can still be relatively normal-ish on a cap displaying bad parameters elsewhere, but a cap showing excessive ESR will definitely show up on the leakage current scale/or display a sluggish charge rate (this is one where you have to chalk up a little experience with old test gear, so have new units to compare against ;).) Sprague units are too old for ESR, but the insulation breakdown test is a crucial one really. Especially on those vintage electrolytics that've just been reformed prior to powering up that amp. ;)
metalhead3ecr
Post by metalhead3ecr » Fri Apr 12, 2013 8:38 pm
ended up getting a cheap craftsman. It'll do for now... :?
demonufo
Post by demonufo » Sat Apr 13, 2013 12:01 am
You don't need to go mad on a multimeter, but a calibration certificate is nice for peace of mind.
