I was thinking Larry ground because I still have a little of that ground buzz going on. It's like single coil buzz but happens on humbuckers too. Definitely not loud or anything, just annoys me because my 2203 doesn't have any of that. My 2203 hums a bit tho, this build has absolutely zero hum. The ground buzz is always at the same volume level, it doesn't get louder or quieter when turning the pots. The buzz exists even when there's nothing plugged in. If I turn normal volume above 3 when using the bright ch, the buzz goes away. Howewer, even when the normal vol is there when I turn bright vol above 6, the buzz comes back again the same volume. From there I can't get it away turning the normal vol. It kind of interacts with the volumes if that makes any sense.
I'm using TAD's grounding scheme except for the vol pots and middle, those go with SDM's alternative ground, ie. buss above the pots through the grounded lugs, input jack and cathode grounds going there, then a wire from the buss to preamp filter caps ground lug. I redid all the solder joints on the buss but no change. The connection to the ground leg should also be good, I checked it many times before putting the board in. Can't really redo that, or at least it would be a major PITA. I tried to check all my grounds and they seem to be good. Only thing I can think of is the solder joint in the preamp lug. Guess I could try to just put a ground lug to choke mounting bolt and run a wire from the buss to that to see if the buzz goes away. Then the buzz could come from carbon comps too, or do they just add hiss?
Dunno, maybe I'm just too worried. I'm too used to my 2203 which doesn't have any kind of buzz.
