2red= HV
violet= bias tap
green= ground
yellow= 12v tap which i dont need, as its for the original amp's switching/reverb circuitry
green/white= heater/ no center tap, so i did the 100 ohm to ground thing......
these are the xtra wires im confused about as they are not on the schematic, but i may need them for my build as im going for another 2204 clone......
**blue.......i need to know what this wire is for..........could this be a bias ground or 5v tap for rect. tube?
**brown/white......i need to know what this wire is for.........could this be a center tap that goes to the mains cap?
**both of these wires are in the same cluster of wires as with the 0-120v mains primaries.
**the blue wire has continuety with the top half of mains/primaries
**the brown/white has continuety with the bottom half of mains/ primaries......
i dont know what this means.....so any help would be great.....
