If it's Springtime in Michigan.....
Replica amps built by George Metropoulos himself. Visit PlexiReplicas.com.
Post by VelvetGeorge » Fri May 20, 2011 1:54 pm
then you know I'm dealing with rain water trying to flood the shop. My headaches came later this year, but arrived none the less. Many day and many inches of rain have kept me busy trying to keep everything dry. Nothing was damaged fortunately, but I did install a new sump pump and drains. I was alarmed to find mold growing in several places, so I am attacking that now.
Regrettably, it is now Friday and I have not built an amp this week. This will push all my orders back 1 week, at least until I can catch up. I'm sincerely sorry for the delay.
At least the kids had fun playing in the new 1 foot deep pond that sprung up in the yard. :shock:
page361
Re: If it's Springtime in Michigan.....
Post by page361 » Fri May 20, 2011 5:56 pm
Hang in there! "May showers bring June profits" ...isn't that how that old saying goes? :)
db_inst_amp
Post by db_inst_amp » Fri May 20, 2011 7:58 pm
Water is the enemy. Gutters are always on my to do list. Such a pain man. I've been there; shop vac, dump, shop vac, dump. sux. Hope the sump works for you buddy.
Have a good one,
Derrick
Only 2 goats were sacrificed in the making of this cabinet.
OnTheFritz
Post by OnTheFritz » Sat May 21, 2011 1:01 am
Water in my basement as well. :? Not too bad on my end, but a pain nonetheless. Move shit around, dry musty stuff off, and wait for the dry dog days of summer. Ironically my front lawn looks like it needs water. :scratch:
Hang in there Geo, people know you're good on your word and reputation.
Post by VelvetGeorge » Sat May 21, 2011 1:16 am
Yeah, this blows. Found more mold than I expected. I need to move lots of stuff and clean thoroughly with this mold cleaner I bought. Then dry and ventilate completely, vacuum with a HEPA grade vacuum, patch the cracks with hydraulic cement and finally................paint with Drylok. I'm taking this mold situation very seriously, erring on the side overly cautious. But that means I'll lose a few more days to this.
Once fixed correctly it should be fine until well after I move the shop out.
db_inst_amp
Post by db_inst_amp » Sat May 21, 2011 8:11 am
Good luck George - What cleaner did you end up using?
I dealt with the same situation watching water pour through a block wall. That side of the house was right next to a leach field for a septic system. smell and nasty water.
Have a good one,
Derrick
62sg
Post by 62sg » Sun May 22, 2011 7:02 am
VG...if you don't have some already, get yourself a couple of dehumidifiers.
JOHN
myfoot
Post by myfoot » Sun May 22, 2011 8:45 am
62sg wrote:VG...if you don't have some already, get yourself a couple of dehumidifiers.
/\ This . I have mine running all the time and have a hose hooked up and draining right into the sump pit.
Post by VelvetGeorge » Sun May 22, 2011 11:25 pm
Definitley! Two right now. I've one for years, but it seems to be less effective than it used to be. I bought a new 70 pint unit. It claims to have the humidity down to 60%.
Overall, this issue has turned into a huge project. I started off over a week ago determined to upgrade the sump pump. Now it's after 11pm sunday night and I just finished air chiswling the old patches and finish off of one whole wall in the shop. I had to remove everything so I could refurbish the entire wall (which has leaked since we moved into this house in 1975) with hydraulic cement and then Drylok. It's unreal the stuff I'm finding. Grout completely disintegrated, parts of the foundation crumbling away....
I discovered more black mold too, which is what really escalated this project. I must address the mold. Which means keeping moisture out, which means properly fixing the foundation and maintaining the sump. Also, keeping the humidity low.
So, that's where I'm at now. Gonna start mixing concrete...
