Here we are forming the caps on initial power up (no tubes yet!):
12xxx Larry Ground
Re: 12xxx Larry Ground
- Gunny Highway
- Gunny Highway
- vanhalen5150
That looks killer Robert. Glad I got those boards too. Work of art man!
- Gunny Highway
- Gunny Highway
- axeman
I wonder if I should still continue to make some 68 chassis?
- Gunny Highway
- Gunny Highway
- axeman
Will here it is. I have to change the OT holes for the primaries and secondaries it also haves the SDM fx loop holes, but not on the face plate.
- IMG.jpg (219.81 KiB) Viewed 5546 times
- rockstah
what about measurements?
- axeman
I'm going to make chassis to sale, why would I post all the measurements?
- vanhalen5150
- rockstah
ah okay.axeman wrote:I'm going to make chassis to sale, why would I post all the measurements?![]()
i just wondered if you knew and what your source was. did you measure one of Georges or an original?
- axeman
I whant them more centerd for the primary and secondary wires. Do you think builders will preffrr having a voltage selector as well?vanhalen5150 wrote:What was wrong with the OT holes?
- axeman
rockstah wrote:ah okay.axeman wrote:I'm going to make chassis to sale, why would I post all the measurements?![]()
No.
- rockstah
ah.axeman wrote:rockstah wrote:ah okay.axeman wrote:I'm going to make chassis to sale, why would I post all the measurements?![]()
No.
- vanhalen5150
Oh, ok. I assume you mean the wall voltage? I guess here in N. America it wouldnt be an issue, however, seeing as though guys overseas have a different wall voltage, they are still only requiring one specific voltage usually, that being higher. I would probably say no, but thats just me.axeman wrote:I whant them more centerd for the primary and secondary wires. Do you think builders will preffrr having a voltage selector as well?vanhalen5150 wrote:What was wrong with the OT holes?
- axeman
AC Cord or AC/IEC? BTW the front face plate will have the JMP on it and the rear face pate will have Super Lead 100 and all the other warning caution stuff you would normaly see on the back also the PI hole will be sized to mate an F&T cap and the power tube holes to fit 8 Pin Octal, Micalex, MIP.
