2203 Build questions
Discuss our latest amp kit.
guitarplayer83
Post by guitarplayer83 » Thu Feb 10, 2011 5:10 pm
Ok I am getting ready to build a 2203. I plan to order the chassis and faceplates from Ceriatone unless there are other options. My question is what size board do i need for the turret board, length, width, thickness? This build will be a jcm800 2203. Thanks.
demonufo
Re: 2203 Build questions
Post by demonufo » Thu Feb 10, 2011 7:51 pm
All depends on which layout you're following and whether or not the pre-amp filter cap is to be on the board, or on the chassis.
So I like purple, okay!!!!!!
guitarplayer83
Post by guitarplayer83 » Thu Feb 10, 2011 8:14 pm
I plan on using the lay out in the mv 100 watt instructions that I downloaded from here. Thanks
axeman
Post by axeman » Fri Feb 11, 2011 12:43 am
Buy the chassis and the board from Nik at Ceriatone, make sure he includes the stand offs and cage nuts. If you don't what to use the Ceriatone board I can sale you mine slightly used.
rockstah
Post by rockstah » Fri Feb 11, 2011 8:21 am
guitarplayer83 wrote:Ok I am getting ready to build a 2203. I plan to order the chassis and faceplates from Ceriatone unless there are other options. My question is what size board do i need for the turret board, length, width, thickness? This build will be a jcm800 2203. Thanks.
Nik's board will work perfectly for a 2203 spec.
Mark
guitarplayer83
Post by guitarplayer83 » Fri Feb 11, 2011 10:58 am
Thanks for the replys. I am trying to keep shipping down ordering from Ceriatone so thats why I was just going to order the chassis and faceplates. I am going to build an AX84 high octain too, I figured I would order the blank board from watts for the 2203 when i order the high octain stuff. Thats why I wanted to know the size of the 2203 board.
[quote="axeman"]Buy the chassis and the board from Nik at Ceriatone, make sure he includes the stand offs and cage nuts. If you don't what to use the Ceriatone board I can sale you mine slightly used.[/quote
How much for the board, and any mods, what type of caps and stuff were used. Thanks
axeman
Post by axeman » Fri Feb 11, 2011 11:17 am
The board is blank with turrets, but if you want I can populated and add the lead wires? I can install Mallory 150, Orange drop,IC, Sozo, and Metall film capacitors with CF or CC resistors and 20g stranded or 22g top coat wire. BTW I have 2203 board from Nik if you needed.
guitarplayer83
Post by guitarplayer83 » Fri Feb 11, 2011 11:31 am
I can populate the board, how much for it. thanks
axeman
Post by axeman » Fri Feb 11, 2011 11:57 am
metro style or Ceriatone 20 bucks
guitarplayer83
Post by guitarplayer83 » Fri Feb 11, 2011 2:38 pm
axeman wrote:metro style or Ceriatone 20 bucks
Metro Style, 20 sounds good p.m. the details and we can work the transaction out. Thanks
