Pow!
Bainzy
Pow!
Post by Bainzy » Fri Nov 04, 2005 4:56 pm
Anyone ever watched any components on their amp burn up?
Tonight I was working on the plexi, and I accidentally dropped a 820ohm resistor onto the huge white resistor for the effects loop while the amp was on, and it exploded and set on fire! It was pretty cool once I'd realised it'd done no harm to anything but the 820ohm resistor... :lol:
Shred Guitar
Billy Batz
Post by Billy Batz » Fri Nov 04, 2005 5:35 pm
Supposedly you can make electrolytics explode.
sub
Post by sub » Fri Nov 04, 2005 5:50 pm
:oops: several times :lol:
once either 10K res (near bias pot) burn up -> changed -> burn up -> changed -> burn up...................... :lol: (this was a shorting powertube)
Lately under board short (Vox AC50) {moved wire} burn up my board --> now this is a smoky leaky board :lol:
I watched these burner stuffs :shock: i had (just about) heart attack
Sub
GibsonMarshallCelestion
Post by Flames1950 » Sat Nov 05, 2005 7:38 am
Billy Batz wrote:Supposedly you can make electrolytics explode.
I may find out when I fire up the JTM45/100.......I know the RS caps in the originals were only 450V rated, but something about that frightens me....... :shock:
Guest 2
Post by Guest 2 » Sat Nov 05, 2005 8:00 am
Damn right you can.
I remember seeing a guy take a 100uf and wiring it up to an extention cord, then he took the other end, and pluged it in a wall plug far away. It was like an m80, maybe even louder.
The same guy used to take mercury out of a common thermometer, and roll it up like a joint, and put a fuse.
That was definately more powerfull than an m80. It blew up a big Pipe Tobbaco can about 100ft in the air, and bent it all up.
And that was just a tiny amount. Mercury is some bad shit.
Billy Batz
Post by Billy Batz » Sat Nov 05, 2005 8:09 am
Sounds like you cake a bomb with 20 1000v/100uF cans linked to a power source set on a timer. Maybe I shoudnt put that idea out there :roll:
rockstah
Post by rockstah » Sat Nov 05, 2005 12:45 pm
Damn right you can.
yikes!
Post by Flames1950 » Sat Nov 05, 2005 6:46 pm
Well, at least our guests finally have useful information to contribute to the world of building amps.
mightymike
Post by mightymike » Sat Nov 05, 2005 9:18 pm
film at eleven
Hazy
Post by Hazy » Sun Nov 06, 2005 10:22 pm
Call me silly...but IMHO Plexi and effects loop sound strange in the same sentence. :?
Toolbox(es) Full of Tubes
Bainzy
Post by Bainzy » Mon Nov 07, 2005 8:22 am
Well it came as standard on the plexi reissue, and it's tonally transparent when off so why not use it? I've found it very useful, it sounds great with effects like delay so I can really add depth to the sound in small spaces. I'd never cut up a real plexi for one though.
Shred Guitar
Hazy
Post by Hazy » Mon Nov 07, 2005 9:48 am
I didn't mean it bad at all. I was just reading the thread and it hit me. Nothing implied by it...really.
Hazy
BrownSound1
Post by BrownSound1 » Sun Nov 13, 2005 1:45 pm
I used to work for a TV and microwave oven manufacturer and I've seen big electrolytics pop many times. This was usually because someone had loaded them with the wrong polarity. Nothing like hearing a pop and seeing foil in the air. :D Smells awful though.
Why is it we can remember where all the wires go, but can never find a pick?
dcaster
Exploding Caps
Post by dcaster » Thu Nov 17, 2005 12:51 pm
I used to work for Magnetek. We made all kinds of products, one of which was a power inverter. When the caps would get installed backwards in the output section of the thing, they would explode. First you would hear a really loud "BOOM" and then the smell. They were filled with FISH OIL! That's right. Every time one of them would explode, it would smell like skank crotch! And it would linger for hours. You couldn't just tell her to go take a shower.
