Need help with board component identification
Discuss our latest amp kit.
LP Freak
Post by LP Freak » Tue Dec 15, 2009 10:35 pm
Is there board component id for the MV kit? I found one for the Plexi style kits in the wiki, but I could use some help on the MV kit. A similar diagram would be nice. :)
Structo
Re: Need help with board component identification
Post by Structo » Wed Dec 16, 2009 12:37 pm
There ya go.
Tom
Don't let that smoke out!
LP Freak
Post by LP Freak » Wed Dec 16, 2009 2:00 pm
Thanks, but I'm looking for something like this but identifying the components on a PTP 2203 board instead.
http://metroamp.com/wiki/index.php/Mars ... components" onclick="window.open(this.href);return false;
Kramer
Post by Kramer » Wed Dec 16, 2009 9:38 pm
You want to put in the Master Volume, right?
All you have to do is apply that diagram to your board. That master volume is not particular to any one amp; it can be applied to any amp. That said, below is the section of the board you linked that you will be modifying. Mind that the .1 and .022 caps are the same position, just different values. So, on the board all you have to do is remove the 2 220k resistors, and then wire in the 3 wires accordingly.
(35.47 KiB) Downloaded 1620 times
(58.66 KiB) Downloaded 1620 times
LP Freak
Post by LP Freak » Thu Dec 17, 2009 6:03 pm
No, I'm not looking to put a MV in. I didn't think my question was going to be so difficult so I'll try again.
I'm trying to learn my way around the board a little better. So when someone refers to say, a 100K at the plate with a 0.68uf at the cathode or a .022uf coupling cap, I know what part of the board they're refering to. So I was hoping someone had a diagram for the 2204 explaining what the different component on the board are like there is in the wiki for the Plexi style board. I hope that makes sense.
demonufo
Post by demonufo » Fri Dec 18, 2009 9:15 am
What LP Freak is looking for is board component identification for the 2203 kit, not a PPIMV kit.
To be fair, there's not actually much different on the board, only a little bit on the LHS.
So I like purple, okay!!!!!!
cagenut
Post by cagenut » Fri Dec 18, 2009 4:00 pm
A lot of us would appreciate that sort of diagram.
SDM
Post by SDM » Sat Dec 19, 2009 11:18 pm
Gotta be smaller to fit on here, but for now hope this helps:
Metro MV component labels.jpg (131.96 KiB) Viewed 2363 times
LP Freak
Post by LP Freak » Sun Dec 20, 2009 10:06 am
Thanks a lot Steve!
cagenut
Post by cagenut » Sun Dec 20, 2009 3:46 pm
Outstanding Steve!
