Clean Up Tip!
Ricky Lee
Clean Up Tip!
Post by Ricky Lee » Tue Jun 21, 2005 9:24 pm
Most of you may have a way of cleaning up the solder splats, but I just wanted to pass this tip along in case it might be of help to someone. I'm really a Klutz when it comes to soldering, my joints generally turn out nice, smooth and shiney, if they initially don't, I keep trying until they do. But when it comes to splatter control the klutz kicks in and I have a mess. Well, I found a product that works really well, simple to use and is rightly named for me. It's called Ooops, and it quickly removes all the splatter without tarnishing the brushed aluminum finish and works just as good on the PTP board, as well. I purchased a can of this at my favorite shopping hole Wal-Mart. When applying, I use a Q-tip which seems to work really well, especially in tight places around tube sockets, between risistors and caps. Hope this helps someone.
Hazy
Post by Hazy » Tue Jun 21, 2005 9:47 pm
I've got that stuff but never tried it on a "splatter". You mean it will remove the resin splatter around these solders on my Bassman?
I'd like to clean this up.
Thanks,
Hazy
Toolbox(es) Full of Tubes
Ricky Lee
Post by Ricky Lee » Tue Jun 21, 2005 11:07 pm
Worked on mine, take a look and I really haven't done a thorough cleaning yet, just got the big stuff cleaned up. You should have seen it before, looked like small-pox.
http://img296.echo.cx/img296/9563/s42000098kb.jpg
dynaman
Post by dynaman » Tue Jun 21, 2005 11:22 pm
Can this product also be purchased from a store that doesn't hire illegal aliens, abuse its employees or support communist China?
Sorry, I couldn't resist. Wrong forum.
Ricky Lee
Post by Ricky Lee » Tue Jun 21, 2005 11:43 pm
Since Wal-Fart is our only major store within 70 miles, we have no choice. Ever heard the song "Down In The Boondocks" they wrote that song about our town. When I need any type of supplies, especially electronic stuff, I spend more in transportation to the place to get it than for the supplies themselves. You don't want to run out of solder in this town, only solder available is plumbers solder, that don't work very well on electronic pieses/parts.
Post by Flames1950 » Wed Jun 22, 2005 12:04 am
It sure doesn't take much soldering on those Fender tag boards before they look like shit, does it Hazy?
I suspect the tag board will always wear its scars like a man......
Hazy
Post by Hazy » Wed Jun 22, 2005 8:16 am
Flames, you are soooooo right. I know it doesn't affect the circuit or the sound; but, it bugs the $%#@I6# out of me. Might try some later tonight.
mightymike
Post by mightymike » Wed Jun 22, 2005 7:21 pm
dynaman wrote:Can this product also be purchased from a store that doesn't hire illegal aliens, abuse its employees or support communist China?
They should put China*Mart on their sign out front.
I couldn't resist either.
