When will you sell
When will you sell
I know I would buy these pre made PPIMV 250ks with the resistors and all, ever think of selling these sense you sell the input jacks pre wired thought maybe this might sell?? I would be in line for sure. These for me is a pain in the ass to make..
Metro 2204
Metro JTM 45/50
Next Super lead??
http://www.soundclick.com/ilovemymarshall" onclick="window.open(this.href);return false;
Metro JTM 45/50
Next Super lead??
- rockstah
when i install a PPIMV i put the pot in the chassis - get my grid resistors in order on the out put tubes.
next i wire everything to the pot from the board. when everything is in place, the connections and the resistor i solder the pots connections.
now i do the same thing with both connections to the out put tubes, connections and resistor and solder the pots connections.
lastly i solder the connections to the output tubes from the pot.
this way I'm able to make perfect length wires for all the connections. and it looks nice.![Wink ;)](./images/smilies/icon_wink.gif)
i suppose it would sell but thought u could use some food for thought on making it less of a pain in the ass.![Wink ;)](./images/smilies/icon_wink.gif)
thxs
thxs mark, my major issue's with the ppimv fitting all the wires in the one wiper, two trimming the smaller wires ? When using the resistors can we use the .25 watters?? smaller, its fitting everything in the one wiper
thanks for the advice I will try that out
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
- Wicksy
The MV Rockstah is describing works a little differently. It replaces the 220K grid resistors with the pot instead of adding one into the circuit.ez_ryder wrote:http://marshallampforum.com/forum/viewt ... t=rich+mod
Simon
went well
Thanks Mark!! I did that way and she came out perfect took my time of course, but she turned out great to the point I need a FX Loop in my JTm45/50 I installed the MM50 and installed both Pre and post and was in wow crunchness but once again I got to get some better speakers, these GT75s I'm sorry there has got to be better for amp to speaker, reamping hey they are fine but amp to cab Na horrible.
Will George ever sell EFX Loops?? I e mailed Steve sdm about his kit.
This amp I'm going to get me or this is my dream list no reamping with her she sounds wayyyyyyyyy to good Im proud of her
I want to
run the front end with Eq and maybe dist + and I want to installed EFX Loops for my delay verb, and of couse speakersssssssss 2/12 to start with but better speakers 25 watters I want 8 ohm
Thanks!!!
Thanks!!!
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
- wdelaney72
It's been mentioned before but I've burned twice, so I'll throw this reminder out there. I don't know if George matches the taper on the dual alpha pots, but I've ordered 10 of the dual 250K alpha pots from Mouser and only 3 of them are suitable to use as a PPIMV. You have to check the resistance on both pots and make sure the taper is similar otherwise it will hum when put to use.
Walter
TY
How much can it be off or do they both need to measure dead on???wdelaney72 wrote:It's been mentioned before but I've burned twice, so I'll throw this reminder out there. I don't know if George matches the taper on the dual alpha pots, but I've ordered 10 of the dual 250K alpha pots from Mouser and only 3 of them are suitable to use as a PPIMV. You have to check the resistance on both pots and make sure the taper is similar otherwise it will hum when put to use.
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
- wdelaney72
Re: TY
I'm not sure what the cutoff would be (SDM????) Mine was about 10K-20K off and it had some hum. Also, they maxed out differently One half was 247K and the other was 254K.IloveMyMarshall wrote:How much can it be off or do they both need to measure dead on???wdelaney72 wrote:It's been mentioned before but I've burned twice, so I'll throw this reminder out there. I don't know if George matches the taper on the dual alpha pots, but I've ordered 10 of the dual 250K alpha pots from Mouser and only 3 of them are suitable to use as a PPIMV. You have to check the resistance on both pots and make sure the taper is similar otherwise it will hum when put to use.
Buying 10 of the Alphas is still cheaper than 1 of the PEC dual pots which with shipping are over $40 each!
Walter
Re: TY
wdelaney72 wrote:I'm not sure what the cutoff would be (SDM????) Mine was about 10K-20K off and it had some hum. Also, they maxed out differently One half was 247K and the other was 254K.IloveMyMarshall wrote:How much can it be off or do they both need to measure dead on???wdelaney72 wrote:It's been mentioned before but I've burned twice, so I'll throw this reminder out there. I don't know if George matches the taper on the dual alpha pots, but I've ordered 10 of the dual 250K alpha pots from Mouser and only 3 of them are suitable to use as a PPIMV. You have to check the resistance on both pots and make sure the taper is similar otherwise it will hum when put to use.
I took it out problm solved!!
When will metro sell the Fx loop kit? G???
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
