anyone has the JTM45/100 voltage chart for new stuff kt 66
all is sayed int the title of the topic ...anyone can tell me ?
sorry, only voltage readings I know of are these:
http://www.drtube.com/schematics/marshall/1959t-66.gif
these voltages (in circles) are spot on in my Metro 45/100
You could ask somone toopen theirs up and do a chart, I think Majorwatt might have one (a Super JH, I believe)
No I think it quite likely that the new amps have lower voltages.
It is my understanding that although they sound pretty good the newer KT66s cannot handle the same high voltages and even Marshall in their blurb acknowledge that the voltages in the amps they are producing will hammer the newer valves pretty quickly.
Suggest a poll of those who have had KT66s go pop, after how much running time and to check if was due to operator failure (ie wrong wire in wrong place etc
) or just failed.
I know Flames popped one on his first 45/100 after a few hours.
In fact I will post poll now
- Flames1950
My first set lasted maybe thirty hours, those were the GT KT66HP's. Sadly I liked them better than the Shuguangs and Tung Sols -- they ghosted less -- but the Shugs and TS tubes sound fine as well.
The Tung Sols KT66's have been in my Super PA since it was built in August '06, but since I'm not a regular gigger at the moment I can't be sure how many hours I've got on it, but I played it pretty exclusively for a few months after it was done, every afternoon when I got home early enough to do so.
- Flames1950
That's what George's original 1202-43 power transformer runs put out, I had little to do with that decision. I do run them a little cold on bias (about 27mA when the math says I could do up to about 31mA) to keep them from dissipating too much heat, but it is still hard on them. Such is the price of being close to authentic.
I'm not sure if his newer runs of that transformer still put out that much -- his flagship '66 clone is only running about 490VDC on the tubes I believe, but I'm not sure is it's the same power tranny that's available in the store or not.
- St August
- wdelaney72
