NOS pre advice wanted!
- toner
I have no experience with NOS tubes and want to get three 12AX7's. I already contacted tubetramp for advice and he recommended a mix of 3 different brands. Considering my amp and tone goals, what would you recommend?
Amp: Marshall 100w reissue, Metro PTP with Sozos and mostly CC resistors, Metro Drake style OT, Metro choke, mainly '67 specs
Guitars: Strats and Les Pauls
Tone goals: 70's AC/DC (especially High Voltage & Powerage), Free, Thin Lizzy, Led Zeppelin, Black Crowes, etc.
Thanks for any help you can offer!!!
- marT
It's really a matter of preference and some trial and error. TT is giving you the most for your money. You can try three different tubes and try them in different positions to find a combination that sounds best. Put them in one order and then swap them around and you should get different results. I like to judge the character of the individual tube itself more so than what name brand it is. One of my favorite combinations though have been a Mullard in V1, An Amperex - Holland in V2 and a Sylvania in the PI.
- wdelaney72
If you got a suggestion from Trampy, go with it... you'll be hard pressed to find a guy who's heard and played more tube combinations than him.
v1 Mullard
v2 RFT
v3 Tesla
v1 Mullard
v2 RFT
v3 Tesla
Walter
- Scumback Speakers
- Supporting Advertiser
I've been less than impressed with Mullards in my JTM 45 clone, but the Amperex Bugle Boy or Orange Globe logo models have worked the best for my tone (similar to toner's tone goals) in that amp. Telefunkens came in 2nd. After that, basically any NOS tube is an upgrade over new stock preamp tubes.
- toner
Well, you got 2 out of 3 from what he suggested! I don't doubt Terry at all. I've read over half of the "Tubes" forum here and have learned a lot (still reading).wdelaney72 wrote:If you got a suggestion from Trampy, go with it... you'll be hard pressed to find a guy who's heard and played more tube combinations than him.
v1 Mullard
v2 RFT
v3 Tesla
The overwhelming general consensus is that NOS is the way to go for the best tone. I'm just sorry I neglected tubes until now.
Thanks for the advice everyone!!!
- toner
Jim,Southbay Ampworks wrote:I've been less than impressed with Mullards in my JTM 45 clone, but the Amperex Bugle Boy or Orange Globe logo models have worked the best for my tone (similar to toner's tone goals) in that amp. Telefunkens came in 2nd. After that, basically any NOS tube is an upgrade over new stock preamp tubes.
What do you not like about Mullards? Do you think the same would apply to a 100w?
Thanks!
I'm still loving your speakers, BTW...
- Scumback Speakers
toner...the Mullards I have just sound like they're a bit mundane and boring. Not enough gain, not enough high end zing. Put in the Amperexs and it was a big improvement.
I've got 4 Mullards for reference, and probably 1/2 dozen Telefunkens, too, but I've bought about 30 Bugle Boys (50-early 60's models) & Orange Globe logo (mid 60's and later) tubes to use with my amp.
Haven't tried them in a 100 watt model, or a JMP 50, though, just the JTM 45. As is well known, the JTM 45 has a bunch of low end so maybe the Amperex tubes are the type of tube needed for that amp circuit, whereas the Mullard or Telefunken is better for the 50 or 100 watt models.
My advice is to get one of each major brand suggested, and swap them around in V1 to find what works best.
- toner
I have noticed some mullard ecc83 short plates are a bit flat sounding and some just blow the doors down, I run a bugleboy in v1 and some great sounding mullards in v2 and v3 so I had to go thru some tubes to find the right tones out of my 45, run GEC dark glass kt 66,sometimes a set of GT HP kt66 those sound real good....
- novosibir
Southbay Ampworks wrote:toner...the Mullards I have just sound like they're a bit mundane and boring. Not enough gain, not enough high end zing. Put in the Amperexs and it was a big improvement.
You must differ between the Mullard I61 and I63bluze81 wrote:I have noticed some mullard ecc83 short plates are a bit flat sounding and some just blow the doors down...
Just with a few words:
The I61 is the blueser
The I63 is the rocker
Larry
I think there's something to that, in guitar amps, although with high variance in both groups.The I61 is the blueser
I would further subdivide the I61s: I find the '50s ones (1st year) can sound a little different than other Blackburn shortplates; I like 'em. IME the early '60s I61s are often among the darkest sounding, some might say flattest. Including 7025 versions. Still good tubes though, IMO.
Talking Blackburn here, not Heerlen, although the latter shows it's own trail of sonic footprints across I61, I63, I65, I66.
Jeff
