JTM45-100 power supply turret board
badfinger
Post by badfinger » Fri Jun 08, 2007 1:48 am
Hi all, Building a JTM45-100 variant, does anyone know where i may be able to get a Power Supply Board for this? or board material? Already built my main board with board material supplied by Ampmaker in the UK, but cant get any material wide enough for the PS board. Does George sell them? Thanks.
(674.18 KiB) Downloaded 315 times
Post by Flames1950 » Sat Jun 09, 2007 4:15 pm
What board material is that in your pictures?
badfinger
Post by badfinger » Sat Jun 09, 2007 11:23 pm
Hi, I Got this board precut but undrilled, from amp maker in the UK, unfortunatley he is not trading at the moment due to ill health, and i dont think its available in wider pieces. Not sure what the board is made from, could be fabric/resin based not sure, but very rigid and stakes well.
I was originaly gonna build a 12 serise amp, got the boards nearly finished but changed my mind, decided to do a JTM100. i was going to convert the 12 serise board to JTM100 spec, but think i might start again from scratch.
After a lot of internet searching i have found some paxolin 3mm sheet, kite grade which i believe is the best grade for electronic stuff, should arrive next week hoping its good enough and looks ok.
I have attached some pics of how i perferated my 12serise board, time consuming, but it works.
(628.54 KiB) Downloaded 204 times
(594.47 KiB) Downloaded 214 times
Wicksy
Post by Wicksy » Sun Jun 10, 2007 7:33 am
Those look great!
Barry should hopefully be back soon. He was supposed to be coming back within a week or so but i believe he is unwell again so here's wishing a swift and complete recovery!
Simon
badfinger
Post by badfinger » Sun Jun 10, 2007 8:19 am
Yes il second that.
908ssp
Post by 908ssp » Sun Jun 10, 2007 10:40 am
Contact Ray he can make you the board you need.
http://smallbox.freeservers.com/
Wicksy
Post by Wicksy » Sun Jun 10, 2007 11:46 am
908ssp wrote:Contact Ray he can make you the board you need.
+1 for Ray. I have two boards he made for me in builds plus a set on the way for a DR103. They look great.
Simon
badfinger
Correct board material
Post by badfinger » Thu Jun 14, 2007 3:54 pm
Well the Paxolin Board material arrived today, quite dark, shiney and with a slight mottled appearance, this is the paper/resin based Tufnol kite. Supposed to be good electricaly and with low moister absorbancy. Seems a little brittle and flakey round the edges
Question! Has anybody tried this stuff? and is it any good? or are the linen/cotton based ones better?
Anyone know what were the original early Marshall turret boards were made from?
Thanks.
(61.11 KiB) Downloaded 499 times
axeman
Re: Correct board material
Post by axeman » Sun May 04, 2008 8:21 pm
badfinger wrote:Well the Paxolin Board material arrived today, quite dark, shiney and with a slight mottled appearance, this is the paper/resin based Tufnol kite. Supposed to be good electricaly and with low moister absorbancy. Seems a little brittle and flakey round the edges
Thanks.
Hi. Can you please till me were I can buy perf board. Please send info axeman6@msn.com Thanks.
WilliamTheSwan
Post by WilliamTheSwan » Mon May 05, 2008 3:42 am
Check the link posted earlier. :wink:
