Chassis
Product sales, customer service, and announcements.
beaulieu
Chassis
Post by beaulieu » Wed Nov 18, 2009 11:22 pm
Is it possible to purchase a 69 Plexi chassis with all caps up top in steel?? How about a MV steel chassis? I saw neither on the stores site! Thanks
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
2550 Silver Jub stack
71 LesPaul Deluxe
68,71,73 4x12
Re: Chassis
Post by Flames1950 » Thu Nov 19, 2009 12:19 am
Well, if it isn't in the store that's your first hint........... :wink:
Re: Chassis
Post by VelvetGeorge » Thu Nov 19, 2009 10:21 am
I'm working with a new fab shop who is happy to do short runs of parts. But that doesn't make it cost effective. If the setup charge on the CNC is $100, you have to add that to the cost of the chassis. So to run a single chassis might cost you $150-175.
If there's enough interest, I can order a short run of those.
Re: Chassis
Post by neikeel » Sat Nov 21, 2009 11:21 am
I might be interested too :wink:
I think a Supertrem layout would be good for the modders out there as you get an extra tube socket and two extra pot holes on the front for gain/masters or whatever, without having to drill extra holes or remove inputs.
Re: Chassis
Post by Flames1950 » Sat Nov 21, 2009 1:25 pm
Personally I would be happy with properly sized 100-watt blanks, that I could build PA's or Trems or whatever on. :D
Watts Tube Audio has stuff that's close.......but not quite right.
Re: Chassis
Post by VelvetGeorge » Sat Nov 21, 2009 2:16 pm
Flames1950 wrote:Personally I would be happy with properly sized 100-watt blanks, that I could build PA's or Trems or whatever on. :D
Steel or aluminum?
Re: Chassis
Post by Roe » Sat Nov 21, 2009 2:25 pm
yes tremolo or PA chassises would be great for modders
Re: Chassis
Post by Flames1950 » Sat Nov 21, 2009 4:48 pm
Steel or aluminum?
Aluminum. Steel is pretty tough on my punches. Simple folded corners would be fine, my Super PA chassis' corners are just folded.
Depends on price too (which of course depends on the interest you get on the whole concept, I know) the Watts 24" is only around $50 -- but of course it's a little short for correct Marshall replicating.
Not trying to to be horrendously cheap on ya, but it seems like I have to find ways to save a buck without losing a quality part whenever I can, or I'm not building anything.
Re: Chassis
Post by Roe » Sun Nov 22, 2009 11:15 am
Andy, TAD sells a blank chassis
Re: Chassis
Post by Flames1950 » Sun Nov 22, 2009 3:01 pm
Yeah, but converted to US dollars that blank is $102, and I haven't even paid to ship it over here yet. That's crazy money for a blank, George's finished chassis are dirt cheap by comparison!!!!
Structo
Re: Chassis
Post by Structo » Mon Nov 23, 2009 7:39 pm
Didn't Watts just post some new chassis sizes?
I thought I had read that somewhere, maybe here?
Or is that what you are talking about?
Tom
Don't let that smoke out!
beaulieu
Re: Chassis
Post by beaulieu » Fri Nov 27, 2009 7:59 am
How about MV... chassis only? I understand if you had to do a "special run" for 69 caps up top. ( I thought you sold that chassis in a kit,in steel) But since MV steel chassis are already available is it possible to buy "just" the chassis for a 2203? Thanks Mark
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
71 LesPaul Deluxe
68,71,73 4x12
Re: Chassis
Post by VelvetGeorge » Fri Nov 27, 2009 11:45 am
My mistake, I was supposed to list the MV chassis after we updated the store. I forgot.
I'll get that listed today.
Re: Chassis
Post by VelvetGeorge » Fri Nov 27, 2009 1:31 pm
LISTED:
http://metroamp.com/store/index.php?mai ... cts_id=533" onclick="window.open(this.href);return false;
Re: Chassis
Post by neikeel » Tue Dec 22, 2009 2:28 pm
Problem with that chassis is the big cutouts for the switches.
A good idea might be to have the chassis made with those shapes but a piece of steel at each corner and a hole in the centre so that you could use the small circular hole for toggles and just have to break through at the corners to enlarge the hole for the large illuminated rockers.
I would prefer a lay down PT option too, but I am just picky :roll:
