opinions on this tone please!
master keeper
Post by master keeper » Mon Feb 27, 2006 12:27 pm
This is my first attempt ever on the VH-tone. What I did was plugging directly into my RI (at my normal settings)which went into hotplate at -4 into 2 cabs. I used my straight checkered and my '70 slant bass BW. The slant BW was miked right at the speaker cloth and the straight was miked from 3ft away. The slant BW is to the left and the straight is to the right in the mix. I used 2 sm57s for the recording, and my duesenberg V for the playing!
Oh, I forgot - I recorded and mixed this on my ZOOM MRS 1266.
Let me know what you think!
http://www.mp3lizard.com/download.cfm?id=19651
rockstah
Post by rockstah » Mon Feb 27, 2006 2:00 pm
sounds great - i mean listening closely to just the tone of the amp and not the way it was recorded. it needs alot of 80hz and below removed but that could be mic placement/mics used- but the tone of the amp rocks!;)
Mark
master keeper
Post by master keeper » Mon Feb 27, 2006 2:58 pm
Thanx, I'll screw around with the sound a bit more, I guess it came out a bit boomy :lol:
Bainzy
Post by Bainzy » Mon Feb 27, 2006 3:14 pm
It could be the mic that's 3ft away - the lower the frequency of the sound wave, the longer it takes to develop. Have a go at using 1 mic off axis (45 degrees) 1-3 inches away, that's my usual SM57 mic position so I'd be interested to hear how your amp sounds with it.
Shred Guitar
mightymike
Post by mightymike » Mon Feb 27, 2006 3:32 pm
Hey Mark how do you set up your mic(s), and what kind do you use.
master keeper
Post by master keeper » Mon Feb 27, 2006 3:43 pm
Bainzy, that's what I did with the mic that went to the BW cab(left channel). Maby it's just the other mic (right channel) that is too loud in the mix?
Bainzy
Post by Bainzy » Mon Feb 27, 2006 3:48 pm
possibly - it seems to add depth and power to the sound but it also makes it a bit distant sounding too. any chance you could cut another mix with just that channel?
Shred Guitar
rockstah
Post by rockstah » Mon Feb 27, 2006 4:10 pm
mightymike wrote:Hey Mark how do you set up your mic(s), and what kind do you use.
Mike,
sm57 pointed straight on - adjusted while i listen to it in head phones. i listen for the best balance between the high end of center of the cone to the bassy side of the paper. ends up being slightly off center. straight on off center of the dust cover.
Mark
Guitar Adjuster
Post by Guitar Adjuster » Mon Feb 27, 2006 4:20 pm
Mike it sound great IMO.
Marc---
No recent clips? BTY--I got the teflon wire in, sweet, I tried to melt it with my soldering iron---no way, got so hot I had to hold it with my needle nose and it still did not melt.
Allen
Guitar Adjuster
Post by Guitar Adjuster » Mon Feb 27, 2006 4:21 pm
:roll: Sorry I meant master keeper--it sound great.
Allen
rockstah
Post by rockstah » Mon Feb 27, 2006 4:37 pm
Guitar Adjuster wrote:Mike it sound great IMO.
Marc---
Allen
more clips to come. i have had some stuff on my plate. but you know ill have more clips;)
i want some of that wire for sure - and the speaker box! :)
Mark
Guitar Adjuster
Post by Guitar Adjuster » Mon Feb 27, 2006 4:52 pm
Mark
Ok this week, I promise.
Allen
rockstah
Post by rockstah » Mon Feb 27, 2006 5:01 pm
coolness ;)
erigm
Post by erigm » Mon Feb 27, 2006 5:56 pm
Masterkeeper,
That sounds real good! It sounds like that amp could use more compression or something. Maybe just some compression in the recording would do it. I don't know ... it doesn't sound exactly like VH, but sounds real real good.
erigm
master keeper
Post by master keeper » Tue Feb 28, 2006 1:51 am
Maby it's because the amp has the 2" ****** instead of a 1.5" opt.
