NOS Tubes 12AX7
novosibir
Post by novosibir » Sat May 17, 2008 8:58 am
@ TubeGetter
Mike, is there anywhere a list with the Tungsram data codes in the web, to check from which year they are? Or do you have a data code list?
I've checked all my orig. Tungsram labelled tubes and found 41 different data codes on it, which are as follows:
07D; 1T; 2W; 290; 490; 4H; 58; 6G; 7I; 7T; 73; 8C; 8M; 8Y0; 9T; AT; D4; E2; E7; G1; G8; G9; H1; H5; H90; I8; I90; M6; M8; M9; MY0; O8; R8; RI; SC; T9; TH; X9; Z1; Z70; ZN
Larry
TubeGetter
Post by TubeGetter » Sat May 17, 2008 10:42 am
Larry, I got ahold of the original table and then re-did it so it would be easier to read (yeah it took a lot of typing). After that I put it in .pdf format. It's for my tube pages that aren't up yet, but here it is:
http://www.cathedralstone.net/Tubes/TungsramDCTable.pdf
There are some quirks with the codes. Any 3 digit codes such as 8Y0, GY0, H90......any three digit code on a tube with a 0 on the end, the 0 is dropped in the table. So keep that in mind. Also, if you study the codes carefully enough, you'll notice they used the same exact codes in a couple of different years. But it's not a problem figuring out which is the right one for your tube, though. Also, as you can see, upper and lower case do matter.
novosibir
Post by novosibir » Sat May 17, 2008 11:02 am
Woah! That a great info, Mike!
Very helpful! Thanks a lot for it!
But I knew before, if anybody has a table, then it's you :D
Larry
5150loveeddie
Post by 5150loveeddie » Sat May 17, 2008 2:55 pm
Where would that code be? I have a "19" stamp on a little metal part under the getter or just above the mica, inside the tube, not on the class..
I see I9 in the chart but not 19????
TubeGetter
Post by TubeGetter » Sat May 17, 2008 3:02 pm
It doesn't look like yours have Tungsram codes on them. Tungsram labeled Tungsrams are pretty much the only tubes that have the yellow codes on the glass, and they can wear off real easy just like everything else. Sometimes the company that relabeled the tube will have their own codes on them, and you find out the approx. dates from that. The tag numbers inside the tubes aren't date codes......likely some sort of batch number or QC number.
5150loveeddie
Post by 5150loveeddie » Sat May 17, 2008 3:10 pm
I see thx.., they must been weared off then...
Here is what I see on both..
novosibir
Post by novosibir » Sat May 17, 2008 4:10 pm
You can't find an original data code on your tubes, because they're RCA labelled and not Tungsram.
The tag inside the tube doesn't say anything of importance.
Larry
master keeper
Post by master keeper » Sun May 18, 2008 2:05 pm
in what pos did you put the tubes?
Post by Roe » Sat May 24, 2008 7:21 am
just got a 9t tungsram from January 1967. thanks for the table tubegetter!
also got a ecc83 labeled itt lorenz - I guess it is a siemens
joshwilson3
Post by joshwilson3 » Sat May 24, 2008 5:55 pm
TubeGetter and Tubetramp,
How much are you selling NOS Tungsram tubes for? I'll be getting tubes at some point for my 2203 clone that has yet to be built.
5150loveeddie
Post by 5150loveeddie » Sat May 24, 2008 10:27 pm
master keeper wrote:in what pos did you put the tubes?
V1
master keeper
Post by master keeper » Sun May 25, 2008 12:52 pm
team it up with another one in V3 too!
razelfrax
Post by razelfrax » Sat Jul 05, 2008 11:31 am
I have 2 tungsrams, shortgray rca's, philips both GT B and Heerlen , Sylvanias, a mully ecc81 and a sylvania 12at7. Would my best starting point for my 50 watt clone be v1 t ram v2 Gt b mully and V3 Tram I havnt had the chance to test this with a band where things sound different but I'm guessing the tungsram cuts through better in a band setting ? Also do you guys find a tone/feel difference between the GT B mullys and the Heerlen ?
Thanks Scott
Very rough Demos lol http://www.reverbnation.com/slp" onclick="window.open(this.href);return false;
Fender Supersonic
2x12 WGS et65's
Custom Shop S1 Tele Relic
Custom Shop 65 Lite Relic Strat
master keeper
Post by master keeper » Wed Jul 09, 2008 9:16 am
heerlen is a bit more gritty than the mule, not quite as dark mid oriented.
razelfrax
Post by razelfrax » Wed Jul 16, 2008 7:10 pm
Thanks master keeper have any of you checked out the 12ax7 shootout clips at pp
Fender Supersonic
2x12 WGS et65's
