New Build: Mojo British 100
Re: New Build: Mojo British 100
Thanks for the help everybody!
And... The hum is now back. Perfect.
Odd question: if the input jacks weren't properly grounded would it cause my guitar to also not be grounded?
I'm still getting noise from the guitar that would suggest that the bridge/strings aren't grounded (I checked continuity and they should be grounded to earth through the amp). So either there's a small grounding issue in the amp or there's an earth ground issue that could cause a big problem if something goes wrong inside the amp (I.e., electrocution).
You must ground the input jacks by a dedicated screw near the jacks.
Ideally you ground the heater centre tap here too (see Larry grounding schem)
- other guitars do it?
I grounded the jacks to a screw securing the filter cap can Under the board. I'm wondering if the jacks aren't fully grounded, though. I grounded the heater center tap to a filter cap screw closer to the power transformer.neikeel wrote:You must ground the input jacks by a dedicated screw near the jacks.
Hmmm. I can check if the guitar does the same thing elsewhere, but I think it's likely to be an issue with the amp and not the guitar.
That is not the same as a dedicated ground.LedZepp007 wrote:I grounded the jacks to a screw securing the filter cap can Under the board.
That is how I would have done it in the past but on a new build the Larry grounding scheme is better.LedZepp007 wrote:I'm wondering if the jacks aren't fully grounded, though. I grounded the heater center tap to a filter cap screw closer to the power transformer.
always worth checking that and if you have close by fluorescent tube or another device plugged into same wall socket etc.LedZepp007 wrote:Hmmm. I can check if the guitar does the same thing elsewhere, but I think it's likely to be an issue with the amp and not the guitar.
Turns out the outlet I was using wasn't grounded properly. Another outlet improved things.
Still the slight 60 cycle hum when the MV is up. Additionally, I got the dreaded "helicopter" noise the other day at high volumes. Filter cap? Bad solder joints?
