Dual Bright Caps?
Posted: Mon Feb 28, 2011 11:58 pm
by somethin'else
Hi Gang,
Does anyone have a drawing for a Volume Pot using a push-pull dual gang 1M (think that's the right one) to have two bright cap possibilities?
Can't seem to find a layout anywhere, and I'm a spud when it comes to figuring it out!
Oh, it's for a 12 Series Metro.
Thanks!
Re: Dual Bright Caps?
Posted: Tue Mar 01, 2011 1:26 am
by Groovenut
somethin'else wrote:Hi Gang,
Thanks!
I dont think the dual gang with a push pull is easily available, however the single gang push pull is. Here are two possible ways to wire it. I tend to use version 1, I find it doesn't pop when you switch caps.
Posted: Tue Mar 01, 2011 11:20 am
by somethin'else
Thanks Groovenut! I've used those plenty in guitars, but they feel kinda chintzy, what about SPST?
Cedist has 'em, which I found on
this thread.
But I'm not sure a SPST will do it. Hmm, need to read up on the functions of those.
I can't remember, are the Volume Pots linear or audio?
Also, found
this thread too on the Split/Shared Cathode switching, and they're using the one you prescribed. THAT looks like fun too.
Hey, Thanks again.
Posted: Tue Mar 01, 2011 11:35 am
by Groovenut
somethin'else wrote:I can't remember, are the Volume Pots linear or audio?
Volume pots are audio taper
Posted: Tue Mar 01, 2011 2:53 pm
by somethin'else
Groovenut wrote:somethin'else wrote:I can't remember, are the Volume Pots linear or audio?
Thanks bro.
On to search for the good pot. er, audio pot.
Posted: Thu Mar 03, 2011 4:38 am
Posted: Thu Mar 03, 2011 4:52 am
by robert
Very flexible!
Plus: they even have the correct thread diameter!
The most Alpha/Taiwan- push-pull pots have the 7mm thread dia only.
Regards
Robert
Posted: Thu Mar 03, 2011 1:33 pm
by somethin'else
wow, Thanks Neikeel, those look really nice. I spotted some from AES, the Alpha 7mm ones, but these look a lot more robust.
I'm assuming you've used these? How do they feel? It's the only downfall to those push-pulls is they feel kind of "light", but I've never tried these. Cool!
Thanks for the link!
Posted: Mon Aug 15, 2022 12:46 pm
by awangotango
anyone have a current link or image on how to wire in a bright cap on a push pull 1meg volume pot? so pull is bright cap on, push in and bright cap is out of circuit?
