Lemco silver mica voltage rating
I purchased these Lemco 470 p csilver mica capacitors hoping they are rated at the corrected voltage but there is no marking. Seem a little smaller than the ones in marshalls. What y'all think? Thanks
Musicians are like a bowl of cereal
If they aren't Fruits or Nuts they're Flakes
Re: Lemco silver mica voltage rating
Probably 350v. Post some pics and hopefully Neil will chime in. He will know.
I think the typical working voltages were: 350vdc, 500vdc, 750vdc, and 1000vdc. The 750v and 1000v had thicker leads. As for physical size, it varied depending on voltage rating and tolerance. A 1% and 2% tolerance cap was larger in size compared to a 5% or 10% cap.
Thanks guys, sorry I thought I posted a pic but apparently this is a thing: "Sorry, the board attachment quota has been reached". Here's the eBay link:
http://www.ebay.com/itm/182157314364?_t ... EBIDX%3AIT
They are marked 1%. About the width of a penny and slighlty thicker.
Thank you all
Thank you all
They appear to be pretty far out of tolerance according to the sellers measurements. Some Lemco's have a voltage rating stamped on the back which the seller didn't post pictures of. Tough to tell from the picture which voltage these ones are, but I don't think they are 1000Vdc....Perhaps Neil might have a better insight.
Thank you, I hope at least they are able to withstand the 1987voltages, crossing fingers. No markings on the backside.
Think they are 350v rating ones (bit smaller than the 500v ones)
They should be fine on your mixers and probably ok in a 50w tone stack, not so good in a 45/100 or early 70s Superlead.
Thanks boss, very much appreciated.
Be sure to use a heatsink when soldering them. I have read several times lately of people having problems with noisy silver micas. It seems that they are easily damaged from overheating when soldering. I have never had an issue but using a heatsink is good insurance to prevent damage. http://www.thegearpage.net/board/index. ... t-22093134
Thanks for the tip, got my heat sink, will do!
Hmm there cant really be that much voltage on the cathode follower. 160ish on a 50w. Whats the cathode followers voltage on those amps?neikeel wrote:Think they are 350v rating ones (bit smaller than the 500v ones)
The 470p will see about 250 off of v2 in a 50 watt.
Metro build gude shows about 150 on 50watts and 170 on SLs.
No, the 470p is off of pin 6. Plate voltage of 270 according to metro chart
No the tone stack is off the cathode Pin 8. Not the plate pin 6.. unless your not building a 1987?
