Everything works great, and sounds good.
The problem when I made a record of the voltage, I have very high voltage readings on the PI pins 2,3,7, &8.
I'll only list the pins on V3, because everything else is in limits.
V3
Pin 1=253
Pin 2=57
Pin 3=155
Pin 4=3v AC
Pin 5=3v AC
Pin 6=260
Pin 7=61
Pin 8=155
Pin 9=3v AC
I have 2 of these amps, and swapped all the tubes, and checked the resistor values.
It is where the 3 resistors tie toghether, 1meg, 470, and 1meg.
Any ideas or help appreciated.
T
