Low bias voltage on 100 watt build
Ivabiggun
Post by Ivabiggun » Sun May 26, 2013 12:09 pm
Hello everyone, I am having a problem with low bias voltage on a 100 watt build. With a 27K bias range resistor I barely got 17Vdc on pin 5 of the PT's. I put in a 10K and got the following results:
Wall outlet: 125Vac
Bias tap: 49Vac
Voltage drop across the 10K: 2.5Vac
After rectification: 20.5Vdc
The diode reads good on my meter so I am wondering what is going on. I have to tell everyone that this is a kit I am building for someone. It comes from a certain company who makes excellent speakers, but as I remember from some previous posts, their kits are not held in the highest esteem on this board. I am using a Classic Tone OT, and a Mercury 10H choke.It is a Chinese PT and I have uploaded a pdf of the specs. The schematic for the kit itself shows the bias being tapped off of the HT winding, but I used the bias tap.
(50.92 KiB) Downloaded 676 times
Here is a pic of the amp with one of my PTP boards installed:
Full view-resized.jpg (227.84 KiB) Viewed 1401 times
And one of the bias supply:
Bias supply-resized.jpg (239.77 KiB) Viewed 1401 times
Thanks in advance for the help and suggestions.
Ivabiggun
"Sign zee papers, old man"
RussB
Re: Low bias voltage on 100 watt build
Post by RussB » Sun May 26, 2013 2:23 pm
I built a Weber kit and used what I would a "Fender Style" bias circuit, IIRC the tap had about 75 vAc
Post by neikeel » Sun May 26, 2013 2:52 pm
Normal bias voltage on a proper Marshall 100w PT (or correct spec clone) is 90-100vac
Ivabiggun
Post by Ivabiggun » Sun May 26, 2013 8:43 pm
Thank you for the replies. I thought we didn't mention Weber on this board. :lol: I guess I will have to rebuild the circuit according to the Weber schematic and tap of off the HT. RussB, that is a nice job on the bias layout.
Ivabiggun
Post by neikeel » Mon May 27, 2013 6:27 am
Ivabiggun wrote:Thank you for the replies. I thought we didn't mention Weber on this board. :lol: I guess I will have to rebuild the circuit according to the Weber schematic and tap of off the HT. RussB, that is a nice job on the bias layout.
Ivabiggun
Probably because it seems to be a form of masochism do make their amps when there are Ceriatone and Valvestorm/Metro and Marstran which are much better products. IMHO!
kararsiz
Post by kararsiz » Mon Aug 12, 2013 5:56 pm
I've been trying to build a bias circuit and I built one yesterday using your schematic. It works fine. I've been getting ~82Vac so I guess that's ok. And this probably means there's some shorting or lose connection at your end which is responsible for the drop.
