I was also wondering about the installation. George says that you should put it between pins 1 and 8, and then to ground (which I guess would be the bolt where the socket connects to the chasis, right?). in a Rockstah post he mentions joining pins 1 and 8, THEN puting the resistor between pin 1 and ground. It also mentions that this might be better. Which is best?
If I use this method, the pins 1 and 8 are already joined in my amp, for grounding. can I then just add the resistor and not do anything else? in which pin would I need to put the multimeter then? (I know in George's method it goes in pin
Last, regarding the filter caps, using alligator clips. the amp should be turned off? plugged???? Suppose I put one alligator clip to the turret with the 100watt resistir that also joins the .022 cap. Can I put my multimeter there also to check how the filter caps discharge?
I want to be sure.
Thanks in advance guys, I am learning a lot!!!!
