100ohms resistor to ground on each side of the heater wires would do the trick?
2watt?
Artificial heater CT for a NO heater CT power tranny!!!
- 5150loveeddie
- novosibir
Yes!
0.5 watts are enough, because nearly no current there.
Larry
Larry
- 5150loveeddie
Thanx Larry
- novosibir
That's right in that cases, when due to a bad or dirty tube socket any pin 3 (plate) is arcing to pin 2 (filament). If the amp doesn't have a H.T. fuse, the resistors are burning open and disconnect the way to ground, hopefully before the OT's primary burns open.scottosan wrote:I've heard from a reputable tranformer maker that using the .5 watt 100 restistor can work better than a fuse in some cased of power tubes shorting out.
After this has happened, the amp has a huge amount of hum and then you'll know, that these resistors are fucked up - and of course one of the output tubes.
But - a H.T. fuse always is better than trust on these resistors!
Larry
