Marshall 1960B stereo x config
How easy is it to re-wire a stereo 4 x 12 cab so that the pairs are in diagonals rather than vertical pairs?
Am I likely to need any extra wire?
- Scumback Speakers
- Supporting Advertiser
Re: Marshall 1960B stereo x config
Depends if it's the stock wiring or an aftermarket wire kit. Sometimes they're long enough to go in an X pattern, but you'll have to check to make sure. Generally you're better off replacing the stock 22 gauge wire with 14-18 gauge copper stranded wire.
- johniss0001
better yet use 2.5mm2 mains cable that will rock over most types of cable out there for rewiring cabs i use that or 4mm wire it does make a difference on the lows and highs
John Ross
Respect the FATHER OF LOUD Jim Marshall
Real easy to do but curious to know why you'd do it.
Cheers to the ears.
- 908ssp
I believe he might have a late model 4x12 with the two 8 ohm stereo inputs. Only reason I can imagine for him to use the word stereo. I still wouldn't do it if I was running stereo as I prefer a vertical 2x12 as it gives better sound distribution.
OK, I get that but I'm not following the diagonal wiring if all 4 speakers are in mono.
Cheers to the ears.
- 908ssp
Wouldn't be mono if he hooked up two amps to the 8 ohm jacks with the switch in the stereo position on the cab.jnewlyn wrote:OK, I get that but I'm not following the diagonal wiring if all 4 speakers are in mono.
I run two amps in mono through the cab (one on at a time) and use it on its side currently for better spread of sound, but hear the top pair of speakers louder than the bottom pair. By using an X formation, I'll hear each amp the same, and retain the spread of the sound.
- Harold
If the wires are too short, you can always unscrew all speakers and put them back in a 90' angle (switch places).
Gibson SG Jr > DP209 > Ross Distortion > JMP 2203, 2204 or 1987x > 1960TV
TANK86 - Instrumental sludge metal!
DIY-Layout.com - Online stripboards!
