Can low voltages harm your amp?
I am curious to know if excessive low voltages can harm your amp ...such as by using a variac and say brining down the voltage to 75-80v or even less.
Re: Can low voltages harm your amp?
There's a tab in the navigation bar that new members may find beneficial. If you have a question, try a "Search" first. This place is a wealth of knowledge, all you have to do is look around. If, after reading the thousands of threads here, you still have no luck... someone will be with you shortly.slashsound wrote:I am curious to know if excessive low voltages can harm your amp ...such as by using a variac and say brining down the voltage to 75-80v or even less.
1 minute on the search and I found these:
http://forum.metroamp.com/viewtopic.php ... ge#p245814" onclick="window.open(this.href);return false;
http://forum.metroamp.com/viewtopic.php ... arm#p83338" onclick="window.open(this.href);return false;
http://forum.metroamp.com/viewtopic.php ... de#p239493" onclick="window.open(this.href);return false;
