JVM 205/210 schematic?
Mats A
Post by Mats A » Fri Apr 24, 2009 4:31 pm
Does anybody have the schematics for the JVM 205/210 amp?
novosibir
Re: JVM 205/210 schematic?
Post by novosibir » Fri Apr 24, 2009 10:51 pm
Mats A wrote:Does anybody have the schematics for the JVM 205/210 amp?
You only have to scroll a bit down on the Board index, then you'll find a forum "Marshall Schematics" :wink:
Larry
Mats A
Post by Mats A » Sat Apr 25, 2009 7:41 am
Larry
But I find only the 410 schematic there and the JVM 205/210 is quite a different beast.
2308to
Post by 2308to » Mon Apr 27, 2009 11:23 am
Here you go 8)
JVM210-67-02-v01.pdf
(63.9 KiB) Downloaded 2491 times
JVM210-61-02-2-v02.pdf
(124.15 KiB) Downloaded 1933 times
JVM210-61-02-1-v02.pdf
(60.71 KiB) Downloaded 1787 times
jvm205-65-02-iss3.pdf
(333.62 KiB) Downloaded 3221 times
Boer
Post by Boer » Wed Aug 20, 2014 6:38 pm
Hy Larry,
The schematic posted are the 210C or 210H?
amporo
Post by amporo » Mon Dec 17, 2018 7:44 am
Hi 2308to,
I could not open your PDF, something going wrong!
sincerely, amporo
danman
Post by danman » Mon Dec 17, 2018 8:06 pm
The link to the pdf is almost ten years old now.
bordonbert
Post by bordonbert » Fri Dec 28, 2018 5:37 pm
It might be 10 years old but the info is still useful. Is there anyone who could repost these schematics as I am in the same boat.
Yes, I can work from the JVM4xx versions but there are a lot of resistor/capacitor numbers at least which are different, and working across multiple pages of schematic is awfully slow when you have possibly incorrect component number references.
alexradium
Post by alexradium » Sat Dec 29, 2018 3:48 am
bordonbert
Post by bordonbert » Sat Dec 29, 2018 12:41 pm
It looks as though the links to the schematics have gone up in smoke so I contacted Novosibir and he still has the originals. I've put each of the two into a booklet now so you can easily get the whole sequence for each amp series. Novosibir is looking at them and may repost them as permanent links on the original reference thread but in the meantime here they are from my own Dropbox site:
JVM2xx:
https://www.dropbox.com/s/4rnml6sulo68l ... s.pdf?dl=0
JVM4xx:
https://www.dropbox.com/s/n1gqurjb5eg1q ... s.pdf?dl=0
They should be available for a long time from that.
EDIT: I'm having trouble getting the system to recognise the addresses somehow if I put them inside its [LINK] tags. I've posted them as raw addresses but once again the system seems somehow to insist on doing that by itself. Hope these stay active and working.
