I have a Marshall 1962 Bluesbreaker Reissue from 1993. The edition I have is the JTM 2*12 combo, 50w with tremolo.
I am considering installing a PTP board kit, but I am not quite sure which one to get.
Metropoulus offers these three variants:
BB Reissue PTP Board Kit
http://metroamp.com/store/product_info. ... cts_id=329
Metroamp JTM 45 Retrograde Kit
http://metroamp.com/store/product_info. ... cts_id=190
Metroamp PTP JTM 45 Reissue Board- Kit
http://metroamp.com/store/product_info. ... cts_id=192
BB Reissue PTP Board kit
Looks like this is the way to go for me but the kit only comes with layout diagrams and schematics, not step by step instructions like the other kits, which may represent a problem for me. But all in all I'd say this is the kit I should use and then add the 16*16 and 32*32 can capacitors to the kit.
Also does anyone know if the components listed below have been switched in order to meet the BB's vintage specs or if I have to order these separately?
Cap (C3) from 330uF to 250uF
Resistors (R16, R18) from 470k to 270k ohm
Cap (C6) from 220pF to 500--550 pF
Cathode resistor R15 from 1k to 820ohms.
Could also be the right way to go since I can order it minus tubes. It comes with an assembly diagram which may be helpful.
But if I use this kit, I will lose the Tremolo channel right? Not that I really use the tremolo channel, but will it represent a problem considering which amp I am going to modify?
Metroamp PTP JTM 45 Reissue Board Kit
Seems to be the same kit as Metroamp JTM 45 Retrograde Kit, less tubes, less can capacitors less bright cap right?
So, could anyone give me advice on which kit to buy to receive the best possible match and which kit will bring me the closest to the original BB specs?
My amp is currently running on KT66's by the way, so the re-tubing part is done. I have also removed the bright cap on the channel 1 volume pot, major mods right there man
Many thanks,
/fredrik
