its done !!!
gibboau
its done !!!
Post by gibboau » Fri Apr 06, 2007 12:22 am
hi guys its done....
Im trying to figure out why the voltage on V1 Pin 3 is under 1volt.. just pulling it apart again to investigate..needless to say i did fire it up and it does work..no weird sounds or crazy stuff going on.....but the volume is low (im assuming it has to do with the above problem)
***still not getting full volume out of the amp, can have both vol knobs pinned and the amps doesn't break up and the mrs doesnt come running in to tell me to turn it down** **seems to be having a low voltage issue** any advise guys?
Mike
Post by neikeel » Fri Apr 06, 2007 7:37 am
Well done feels good doesn't it!
However, where are you losing the voltage?
At the top of the 10k/8k2 resistors you should have 420-440v (downstream of the choke where the OT screens come off and a filter cap). ie your B+ plate voltage.
If that is ok trace it across to the PI plate resistors should have 380v or so there.
Then the diagonal link to the other two 10k resistors each one should drop by 70v or so, such that at the junction of the two 100k V1 plate resistors you have 300v and about 190v without valves in.
To steal atip from SDM :oops: is the end lug on your presence pot hooked up to the earth bus wire on the back of the pots? If they are not the PI will not be earthed and not much juice will flow!
I guess more pics would be good.
ps I wish everyone would pull their wires through the board and wrap them round the turrets late 60's/early 70's style. Then you can see what is hooked up to what and not hidden under the board :roll: even if it looks prettier with them hidden, after all your link wires are on top.
I have not got xray vision like the pro trouble shooters :wink:
gibboau
Post by gibboau » Fri Apr 06, 2007 8:14 am
hey Neil thanks for the replay, here are some more pics
P3 of V1 is only reading 1Volt... this is driving me nuts :P
i have 429v at the top of the 10k 2w/8k2 2w resistors
sorry to be a newb but im not sure where the PI plate resistors are...??
at the junction of V1's 100k plate resistors im getting 417v...(without valves)
im using a bill batz layout with a split 16/16uf can for the pre amp filter (could this be the cause of the high voltage at V1's plate resistors?)
and the end lug of my presence pot hooked up to the earth bus wire on the back of the pots as well
(103.89 KiB) Downloaded 259 times
(105.45 KiB) Downloaded 277 times
Mike
Post by neikeel » Fri Apr 06, 2007 9:30 am
gibboau wrote:hey Neil thanks for the replay, here are some more pics
These are the 82k and 100k resistors tied by the 47p cap
If you have 400v at junction of the 100k resistors there is a problem with the resistor or the joint from which the blue wire goes to the valve base or there is a problem with the 0.022uF caps to your volume control (highly unlikely)
Not really as long as the cap is hooked up properly and the earth secured to the other earth point on the other filter cap lug and your dropping resitors are correct, voltages are ususally higher without valves in (5-10%)
Good
gibboau
Post by gibboau » Fri Apr 06, 2007 5:52 pm
thanks neil,
ill ive tests all the resistors in that area and they all tested fine..i will continue to poke and prod until i find whats going on... it maybe a wiring error or a tone cap... at least i know it does make sound or be it a little soft.. the neighbors are safe for the moment :twisted:
Mike
gibboau
Post by gibboau » Sat Apr 07, 2007 3:27 am
ok guys, looks like i sorted the problem out..i rewired all the pre amp tubes and what do you know it seems to be working fine.....the volume is now strong enough to get the mrs running in telling me to turn it down... when you pin the volumes it produces what i would call the best sounding distortion ive ever heard.....
long live metro amps i say !!!!!!!!!
Mike
gibboau
Post by gibboau » Sat Apr 07, 2007 3:39 am
just put it back on the bench and the V1 P3 voltage has gone south again :cry: the amp is still very musical... so i wonder if it will still be ok reading a lower voltage on that pin
cheers
Mike
SDM
Post by SDM » Sat Apr 07, 2007 4:37 am
You are running a split cathode setup on V1 in there right? So V1 pin 3 goes to the 820 ohm cathode resistor (and it's bypass cap)? If so, you should have around a volt (or a bit less typically) there on pin 3 if things are working/hooked up right. Not sure what you expected, but looks like you are all good there.
gibboau
Post by gibboau » Sat Apr 07, 2007 4:55 am
hi Steve, yeah split cathode... i was expecting 1.8-2v on that pin (from the 50w voltage chart i found on the forum) needless to say the voltages on that chart didnt quite match the onces in my amp... (im assuming not all amps are created equally) im happy to report the amp rocks like no other ive owned.. it even makes my 94' twin amp sound "well" shit...
Mike
SDM
Post by SDM » Sat Apr 07, 2007 5:18 am
Hey Mike, not sure what chart you were going by, but yeah many things can throw you off from any given voltage chart. For example the charted amp has a shared cathode V1, the V1 triodes are swapped around, just different cathode values used, altered/different circuit, higher/lower B+, the current the particular tubes draw themselves, recording errors, etc... :shock:
Anyway congrats on the successful build!
Post by neikeel » Sat Apr 07, 2007 5:21 am
gibboau wrote:just put it back on the bench and the V1 P3 voltage has gone south again :cry: the amp is still very musical... so i wonder if it will still be ok reading a lower voltage on that pin
cheers
If it sounds good...................................... :wink:
gibboau
Post by gibboau » Sat Apr 07, 2007 5:44 am
hey guys,
here is the voltage chart : http://members.shaw.ca/house-of-jim/Html/Marshall.html
im just going to leave in a "as is" state and forget those voltages.. again there is no strange sounds or weird going ons
Mike
Janglin_Jack
Post by Janglin_Jack » Sat Apr 07, 2007 6:06 am
I am certainly impressed with your wiring. Very neat, well done!! Good luck with the trouble shooting.
I know when I did my build, I checked, checked and re-checked all my wiring over and over. With the exception of the OT wires reversed on the power tube, (man did it squeal like a banshee). My fired right up.
Keep looking, you will find it!!
Jack
gibboau
Post by gibboau » Sat Apr 07, 2007 7:57 am
thanks jack for the comments on the wiring...i still think it could be improved. im going to go back and put the wiring though the board like nick said.. it gives is more a a 60's look :wink:
Mike
SDM
Post by SDM » Sat Apr 07, 2007 8:00 am
gibboau wrote: im just going to leave in a "as is" state and forget those voltages.. again there is no strange sounds or weird going ons
I think you are all set, but just for the hell of it, drew up this chart of the ballpark voltages I would expect with your amp (430 V B+ and this version of the 1987 circuit taken into account). Did it kind of quick with no amp in hand, but hopefully it's pretty accurate.
