Stock 68 spec W/2"OT and such...
vanhalen5150
Re: Stock 68 spec W/2"OT and such...
Post by vanhalen5150 » Fri Jun 08, 2012 2:30 pm
What's DHS?
vanhalen5150
Post by vanhalen5150 » Fri Jun 08, 2012 2:32 pm
Dudes of Homeland Security?
vanhalen5150
Post by vanhalen5150 » Fri Jun 08, 2012 3:27 pm
vanhalen5150 wrote:Dudes of Homeland Security?
I did a search on that word in Metroamp. There are 38 pages of different threads with that word. :lol:
rgorke
Post by rgorke » Fri Jun 08, 2012 4:44 pm
Yeah, you got it. Funny there are that many posts.
Strat78
Post by Strat78 » Sat Jun 09, 2012 8:59 pm
Check out these dogbones, everyone needs a little hippie in their amp.
vanhalen5150
Post by vanhalen5150 » Sun Jun 10, 2012 9:10 am
What the........ :shock:
vanhalen5150
Post by vanhalen5150 » Mon Jun 11, 2012 7:55 am
Strat78 wrote:Finished the build last night and she sure is purdy. :drool: I'll call it the "knee" amp sense it brought some distraction from the 24/7 f'n pain from the surgery. Built most of it in bed from 2am to 5am each morning. I'll form the caps this afternoon and do a readings chart tomorrow. I really want to hear these new tranny's! :D
Did you have to redrill for the OT's? Im putting in the 2" for this one I think. The rubber grommets sit half under brackets. Did the 1.5' fit correctly?
Strat78
Post by Strat78 » Mon Jun 11, 2012 8:17 am
I ended up drilling four new holes for the 1.5" OT just to get it in the right spot and not cover the grommets. The 2" looks like a bigger problem especially with those new brackets, maybee take a some metal off the brackets to free up the grommets.
Post by neikeel » Mon Jun 11, 2012 8:26 am
Funny you guys doing this!
My early '68 Superlead was punched for a 2" trannie (presumably Drake -132) originally but was hand drilled at the factory for the 1 1/2" Dagnall C1998 (I discovered when I removed it), odd how things go round in circles :?
vanhalen5150
Post by vanhalen5150 » Mon Jun 11, 2012 9:09 am
I'll take some pics tonight before I drill anything later in the week. The grommet holes are about 50% covered by the brackets. Wouldnt be bad but the bracket goes all the way across the bottom, and just doesnt sit well on top of the rubber. I may move the OT a little further away from the PT anyways. The brackets make everything seem really close together.
rgalpin
Post by rgalpin » Tue Jun 12, 2012 8:27 am
Strat78 wrote:So here is a short clip. The tone in the room was horrid and the feedback was beyond control, I seriously wanted to hang it up today. However, somehow something better came through on the recording, it's not great, but the gain and hair is sort of nice. I'm going to switch the tap over to 16ohm and look into waxing this old Mighty Mite #1300. Still frustrated though, kind of just spinning my wheels here.
http://soundclick.com/share.cfm?id=11683786" onclick="window.open(this.href);return false;
THE STUFF RIGHT HERE!! daggggone dude. SICK. Everything about it is to droooool over.
Looking quickly through the comments after you posted that clip - i missed any info about the details of the clip...
how loud? Are you attenuating?
any boost going int the front?
and finally... uh... this: :worthy:
Strat78
Post by Strat78 » Tue Jun 12, 2012 11:05 am
That clip was just a tone test for my latest 12 series build. I don't know what it is, but I always have a problem with too much gain so it's a huge challenge trying to control the amp while playing. It is attenuated just a bit only to protect the cab and is very loud in the room, the pickup is squealing like mad. Nothing in front except an old echoplex. I am stubbornly trying to keep things pure: guitar, echoplex and amp that stays within the parameters of the various stock inconsistencies from 67 to 69. Oh, here is layout for the 1959, including the pre-filter cap, hope that helps with the cap change. As long as you have enough wire to lift the cap from the top it should be no problem swapping in the 16/16 cap.
rgalpin
Post by rgalpin » Tue Jun 12, 2012 11:28 pm
Thank you. Most helpful. :thumbsup:
Strat78
Post by Strat78 » Tue Jun 19, 2012 9:50 am
I liked the look of some original 68 Marshalls that have the little tag strip for wiring different voltage taps. I think it is also used to mount the capacitor for the polarity switch. Anybody ells know what these little strips housed, sometimes you see a couple of resistors on this board as well. I like how the little board hides the extra wires, it looks better than just bundling them off to the side. Robert, can you still get those longer eyelet turrets that George used on his boards, if so, I'd like to order a bunch. :D
(535.4 KiB) Downloaded 501 times
Strat78
Post by Strat78 » Tue Jun 19, 2012 11:50 am
Here is an original amp with the tag board.
