Forming filter caps
- Doug H
Re: Forming filter caps
can you rescue a cap that has been run without forming? or is it too late once a cap that needed forming has been wired up and run live.
Great stuff.novosibir wrote:Forming filter caps...
- disconnect the yello wire going from the PT between the first two filter caps, temporarily tape the unsoldered end for safety (100W only)
Just to triple check. This is the red/Yellow wire (center tap) on the regular PT.
- novosibir
No prob with newer caps, which also w/o forming it will be within acceptable ESR & leakage current values.Doug H wrote:can you rescue a cap that has been run without forming? or is it too late once a cap that needed forming has been wired up and run live.
Older caps are raw formed then, no chance to rescue it, except you store the cap again for at least 5 years and then form it. A raw formed filter cap almost always will have remarkable higher ESR & leakage current than caps formed after my suggestion.
Larry
- novosibir
I don't know, about which amp and which PT you're speaking! You know it, but not megluke wrote:Just to triple check. This is the red/Yellow wire (center tap) on the regular PT.
By all means the original Marshall (Dagnall) 100W PT does have a yellow wire as the CT of the HT secondary.
Larry
Sorry, Metro 100W kit. The standard PT secondary is two red + red/yellow.
- novosibir
Ah-ha - american color code, not britishgluke wrote:Sorry, Metro 100W kit. The standard PT secondary is two red + red/yellow.
Then red/yellow instead of yellow has to be disconected temporarily.
Larry
- 5150loveeddie
Re: LCR dual caps with the Dummy terminal?
Thx Larry!!novosibir wrote:Every resistor does have two leads - or two terminals - and you always have to connect both leads, that a current can flow through the resistor at all. When you now disconnect only one lead of the both, the current flow stops immediately...
... but the current doesn't care about, which of the both resistor leads you've disconnected![]()
If you're still in doubt, then remove both resistors entirely and put it back in place, after you've done.
Larry
- roylfuchs
Why in the heck doesn't George include this step in his instructions for the kits? I didn't know about this procedure and I've been running the amp ever since without doing it.
"This country's goin' to tha dog's!"
- novosibir
When you're using brand new filter caps, the benefit of forming it isn't too much of a difference, also depending on the cap's manufacturer. Marshall, Fender, aso. never formed filter caps after the amps were finished... But I recommend forming filter caps by any means, also when it's effect with brand new caps sometimes isn't more than just like to open up the last 10-15 horsepower out of a Formula 1 engine.roylfuchs wrote:Why in the heck doesn't George include this step in his instructions for the kits?
Larry
- 5150loveeddie
LArry, the method works great, I've revived a jtm45 from 1965 and a SL from 1971 they all came back to below 5v accross the 100k after 30hrs plus+, only thing I was worried is exceeding some cap(s) maximun voltage specs, specialy on the SL from 71, It had near 500v on some caps and they are allowed 450v so I had to reduce my wall voltage with a variac to about 100-105v to stay below 450v on the highest cap in there, same happen with the JTM45, voltage went up to 470v after a while....
Whitout the tubes in there drawing current you will exceed in lots of cases that max cap voltage in one or two of them in the amp depending there position in the circuit. So I guess we MUST reduce that I suppose!!
- novosibir
Yes this has to be considered by forming caps, that the higher B+ due to no load w/o tubes doesn't exceed the max. voltage rating of the caps! Almost always a 470K/1W or a 220K/2W resistor right after the rectifier from B+ to ground helps to pull the increasing B+ down enough.
Don't confuse anything here! The 'pull down' resistor has to be connected right after the rectifier diodes, but still behind the temporarily used 100K (current limiter) resistor, so that this one hasn't to draw the additional current of the 'pull down' bleeder
Larry
Larry
- 5150loveeddie
Ok so basicly we could stick a "pull down" resistor in series with the current limiter resistor (100k) making sure the pull down is first after the rectifier B+? .....novosibir wrote:Yes this has to be considered by forming caps, that the higher B+ due to no load w/o tubes doesn't exceed the max. voltage rating of the caps! Almost always a 470K/1W or a 220K/2W resistor right after the rectifier from B+ to ground helps to pull the increasing B+ down enough.
Don't confuse anything here! The 'pull down' resistor has to be connected right after the rectifier diodes, but still behind the temporarily used 100K (current limiter) resistor, so that this one hasn't to draw the additional current of the 'pull down' bleeder![]()
Larry
- novosibir
No, not in series with the 100K! From still behind the 100K (rectifier side) to ground, like a bleeder resistor.5150loveeddie wrote:Ok so basicly we could stick a "pull down" resistor in series with the current limiter resistor (100k) making sure the pull down is first after the rectifier B+? .....
Larry
- 5150loveeddie
Ah ok I get it, thank you Sir!!!
something like this right?
- untitled.JPG (21.81 KiB) Viewed 5439 times
