12XXX Build 05/2010
- vanhalen5150
Re: 12XXX Build 05/2010
Attenuate low or slave everything on 10. Plug in that Greco Destroyer to the GE 10 set at -6db. Play the first chords of YRGM.
Yo guys! Check YMI5150's thread... I have a question about how you grounded your front panel pot ground buss!
- Gunny Highway
- Gunny Highway
- Strat78
Ok, so heres some dumb questions: When referring to "turning up the bias", that means the number is getting smaller (like-37 to -33)? Also for the power tubes, if the bias measures on V4 -33, V5 -32, V6 -37 and V7 -35 does that men V5 is the hottest tube?
- vanhalen5150
Thats a good one. I dont know.Strat78 wrote:Ok, so heres some dumb questions: When referring to "turning up the bias", that means the number is getting smaller (like-37 to -33)? Also for the power tubes, if the bias measures on V4 -33, V5 -32, V6 -37 and V7 -35 does that men V5 is the hottest tube?
My previous posts were misleading about about the polarity of the voltages:
At pin 5 you should have negative volts(~ -50v)
When biasing at pin 1, you should have positive millivolts(~ +35mv), depending on the plate voltage your running.
Hotter would be a more positive mv reading at pin 1.
- Gunny Highway
- Gunny Highway
- YMI5150?
thought i'd check in with you guys. still on vacation and am anxious to get back to the amp and complete break in.
are you guys running your amps straight and happy with the output or are you pushing it with a GE10 or MXR to get it where you like it?
hope all's well
\w/
hope all's well
\w/
- vanhalen5150
- YMI5150?
slaved? attenuated? MV? or just friggin' loud?
just want to know how you guys are setting yours up to get Zen...
My Mighty Mite Vintage w/ A8 has been potted and is on its way back. will be there when I get home. can't wait...
I need to get some time on it and post clips.
- vanhalen5150
I just been using a hotplate attenuated. Havent even tried the MV yet. Golf is getting in the way of tinkering this summer.
- vanhalen5150
I've blown the mains fuse twice now. Are some fuses better than others. Just cheap Radio Shack versions. It never blows when the amp is on though. It's either blowing when the amp is turned on, or when it's being turned off. Eventually I'll turn the amp on and discover the fuse is blown.
- chrisom
"I see you have constructed a new weapon; Your skills as a Jedi are now complete..."
- darth metro.JPG (47.3 KiB) Viewed 12320 times
- vanhalen5150
- stusixtysix
make sure you are using a slow-blow (sometimes called Time Delay or marked *AT where * is the Amp rating) fuse for the AC mains. The initial inrush current of cold valve filaments/ filter cap charging etc can momentarily exceed the fuses working rating. After a few cycles on and off the heating/cooling of the fuse wire by the current surge, though otherwise in the correct rating, can cause the fuse to fail even though no other fault is present.vanhalen5150 wrote:I've blown the mains fuse twice now. Are some fuses better than others. Just cheap Radio Shack versions. It never blows when the amp is on though. It's either blowing when the amp is turned on, or when it's being turned off. Eventually I'll turn the amp on and discover the fuse is blown.
"...i am a victim of the science age..."
- vanhalen5150
- vanhalen5150
I put in the slow blo's. Havent had a problem since. I can now rest in peace. Golf is also over
....time to start some mods.
