eruption
rockstah
Post by rockstah » Sun Jan 29, 2006 8:38 pm
thank you very much - i enjoy giving back to this community if i can at all.- i have gained some much from the brainiacs here. - if i can give anything back it makes me feel good to have some kind of exchange for what i have gained.
Mark
guitar007
Post by guitar007 » Mon Jan 30, 2006 1:23 pm
Can someone post the pic of Ralle's rig? I must have miss it. Thanks. 8)
~guitar007
mightymike
Post by mightymike » Tue Feb 07, 2006 7:55 am
Some of the modeling stuff has the effects chain dialed in pretty damn accurate, and with something like Eruption, it makes a big difference, because there's a certain timing on the delay and Phase sweep that is crucial. Years ago, I wrote down the values on an Eruption Patch from the taboo twin, and used that to dial in my effects on my transfex.
I owned a lot of this type of stuff, and it's great until you use it in a band situation, and try to push through the mix. They record great though, on the comp using the spdif. I have some Eruption patches for the Peavey Transtube/Transfex, and for the Cybertwin if anybody wants to try them.
One guy told me once that the "not pushing through the mix" problem is solved by running these modeler amps through the PA. I never got that far. Once I started building building 100 waters I pretty much have been
going dry live. The room filling dynamics are my effects.
One little trick some people do is they'll use a combo modeling amp as a wet cab hidden behind their dry Marshall stack. Dialed in right it doesn't sound half bad, and you can push through the mix. To me it's a novelty, yet fun for short spurts.
Great Playing Mark as allways
rockstah
Post by rockstah » Tue Feb 07, 2006 1:23 pm
i hear ya mike - my thoughts are once we have effects ( in our pods or whatever) we over use them and thus get lost in the mix- i use the podxt on the road through two marshalls for stereo. i am mic'd on stage through the pa. easy to get lost when ya go effect crazy( verbs and delays) and one always has to hear how they are going to sound in the mix. no verb live for me unless the song has alot of space in it, ie ballads ;) as far as eruption u r right the effects are crucial. i dont hear delay so much as i hear predelay of verb. when trying to dial that sound in - the chromatic line down before the dive bomb lets you really hear the predelay of the verb... wap( slap) wap( slap)wap ( slap) wap( slap) wap ( slap) whaaaaaaaaaaaa - just make the phaser go as slow as it will go with no feedback mix to taste( 40-50%) - the predelay as i have worked it out is about 253 milisecs;)
happy tapping!
thanks for the post mike!
Mark
mightymike
Post by mightymike » Wed Feb 08, 2006 7:17 am
Forgot to say Reverb which is a key ingedient for Eruption.
253 milisecs is pretty close to the value in that Roctron Taboo twin Eruption patch, which I think was
around 270. Come to think of it, it might have been a dual Delay with one side at 270 and another pretty close to 270, maybe 240, lots of Verb, slow phase. It's really fun until about the millionth time you play Eruption.
Back in the 90's when I thought all I needed was the right effects, I ripped patches from all kinds of processing gear, even if I didn't buy it.
I would just get out a piece of paper and write down all the values,right in the music store, then go home and try it with my pedals or with my processing gear.
The only patches that really stood out was the Boston Patch from the
digitech 2112 which is a POS, but the patch was cool.
And the Rocktron Voodoo valve 2 or taboo twin - Eruption patches
I also have a couple books on effects and settings for signature sounds.
Guest
Post by Guest » Thu Feb 16, 2006 7:54 pm
Not happening. Work on it. Copycat! :wink:
rockstah
Post by rockstah » Fri Feb 17, 2006 2:56 pm
mightymike wrote:Forgot to say Reverb which is a key ingedient for Eruption.
predelay of 253 mil time 1.7 mix 30% was what i used ;)
npminard
Post by npminard » Sat Mar 25, 2006 6:28 pm
Sounds great, rockstah.
What type of Strat is it...Squier, Mex, or USA? Would like to see more pics if you have any.
rockstah
Post by rockstah » Sat Mar 25, 2006 6:45 pm
its a california strat with a jim wagner darkburst pickup with a A2 magnet.
thanks man.
ill see if i can throw some pics up.
Mark
npminard
Post by npminard » Sat Mar 25, 2006 9:15 pm
Thanks for the info, Mark.
I'm planning on doing a similar Strat project, replacing the single coils with one bridge position humbucker. Did keep the volume knob only or is that the tone knob?
rockstah
Post by rockstah » Sun Mar 26, 2006 2:41 am
sure man. i went out and got extra pickguard. chewed it up some. the guitar had a route big enough to just fit the humbucker in. i just used the original single coil mounting screw holes and cut out the guard to fit.
one 500k volume pot is all it has.
Mark
