have had a look at your build - looks nice and tidy
There are no glaring errors that I can see.
When I asked about wire dress I talked about keeping preamp wires apart and the plate wires and grid wires apart. I see a couple of places where that is not the case.
I would also shorten the grid wires on the output valves (that twisted loop around top corner of the board)
Does your amp cab have an aluminium shield inside?https://www.zouser.com/
‘69 era 50 Watt Plexi build squealing problem
Re: ‘69 era 50 Watt Plexi build squealing problem
Thanks to all that have replied with helpful suggestions. I have now sold this amp head on. I did inform the new owner about the squealing problem and he is not fazed by it. Says he knows an amp guy who will be able to sort it! I wished him the best of luck! ![🙂](//cdn.jsdelivr.net/emojione/assets/svg/1f642.svg)
![👍](//cdn.jsdelivr.net/emojione/assets/svg/1f44d.svg)
