Hi guys,
I was looking to add the zero loss loop to the soldano hotrod, with an additional master volume control for the effects return as Mike himself would describe. I've read people would use the zero loss board wired to the original jacks, take signal directly after the LDR switches.
Do you any of you guys have some build instructions/pointers I can forward on to my amp guy? Would be really appreciated.
I want the amp to have a traditional effects loop basically and it sounds like the best way is to leave the original loop circuitry in place, connect the jacks from that to the new board and have another master volume for effects return before power amp. The existing masters are now channel sends etc.
Sorry if this has been asked before, I couldn't seem to find a similar post here
Cheers
Soldano Hotrod50 zero Loss loop modHi
