Slaving a Plexi Project
Re: Slaving a Plexi Project
I sold my Matrix, too. I felt that it was changing a the mids a little bit. The thing is my old, cheap PA power amp sounds better in a Slaving setup but has not enough power and is heavy, so I'm looking for a linear light weight power amp in the moment. I don't want a tube power amp because those that I tried coloured the sound too much.
Hi
Id like to try slaving but not sure my setupbwould work.
What i have is a plexi marshall, 4x12 cab and a weber mini mass 50.
What id need to get is a solidstate power amp like the marshall valvestate power amp.
My idea is, from the marshalls speaker output to the mini mass 50 attenuator's input. Then hook a small 1x12 cab from the mini mass 50 output just to be on a safeside loading the amp correctly.
Id also set the mini mass to low level as possible and it aint gonna be all quiet but atleast low signal from the 1x12.
From the mini mass line out jack to the input of the marshall valvestate poweramp. From power amp to the 4x12 and mic that 4x12 up.
Would this thing work?
Can i control the over all volume from the 4x12 by using the power amps volume control.
If the 1x12 is still annoyingly loud even in lowest settings of mini mass, i could cover that up with pillows and such.
It could work, but it would be much better if you get the Suhr Reactive load so you don't have to use the 1 x 12 cabinet as a load. I'm not familiar with the Weber mini mass 50 but some units have a low pass filter on the line out which would make your amp sound dark. Since a typical Marshall cab with Celestion only goes up to 5 or 6Khz it actually acts like a "lowpass filter" I use an RJM mini mixer and eq before going into the power amp. The eq gives you options to tailor your tone depending on how loud you're playing or what type of tone you want
You could also split the signal to ad effects if you have a mixer. I run one Marshall 1960B cabinet in stereo or 2
Suhr PT100SE ,Metro/Friedman 68' Plexi, ,Friedman BE100,EVH 5150iiiS,Fender Vibrolux 68'/Alessandro,VoxAC30,Kemper
[/quote] I own both Suhr Reactive Load and Fryette Powerstation and they're both very useful. I use an eq after the Suhr Reactive Load to tame the top end and tighten the low end. The Powerstation is great if being used with it's own power amp but not so well as just a load. The Suhr Reactive Load sounds great with many amps but you'l have to slightly cut- 1db of 2k or 4k and up with an eq to tame down the high frequencies. It's much more natural to cut than to add in my opinion. I'm using the Suhr Reactive Load with an Ampete 444 amp switcher slaving 4 different amps and I'm using an RJM mini Gizmo with 5 loops with different eq curves(3 different eq units) for different tones and to match the amp I'm using. it sounds great! I'm using a Mesa Boogie 2 90 as the power amp.
[/quote]
Hi Guys!
I am slaving my amps through my Suhr RL, sending that line-level signal into my rack mixer (i.e., with Eventide rack FX), and then into a VHT 2/50.2 power amp and GB-loaded cabs.
It sounds great to me!
But here is my question......I read about people using an external EQ to tweak the highs a bit.....but I'm not sure why they do this, if that signal is eventually hitting guitar speakers....the speakers are essentially a filter....
Just curious....
Thanks!
Ian
[/quote]
Hi Guys!
Just curious....
Thanks!
Ian
A speaker is a fixed filter, and an eq before the power amp gives you the option of shaping the tone more.
Hi Guys!
Just curious....
Thanks!
Ian
[/quote]
I use the eq because I like to have control of the amp post distortion. If you use your rig for gigs, it would help you shape your tone depending on the acoustics of the place. It also helps if you’re using someone else’s cabinet like when you go to a rehearsal that supplies the cabinets. The speaker is a filter that only cuts anything above 5-6k.Some speakers have too much 4K, 2k or other frequencies that you might not have control by just using you’re amp’s tone control.
Just curious....
Thanks!
Ian
[/quote]
Hi Guys,
I slave my amp into a Suhr Reactive Load, and send tvat line level signal into my FX, and into a VHT power amp.
I have read on this board that some guys slave their amp, and instead of running a line level signal into a separate power amp, they run the speaker output of the slaved head into the input of a second amp......
Why do they use this approach vs sending a line level signal to a stereo power amp?
Is their a sonic benefit associated with running into the front end of an amp?
Thanks!
Thanks!
I recorded this EP with my old band some years ago using my slave setup. Maybe not the tightest performance, but you get the idea.
Setup was: Les Paul with Bareknuckle Mule -> ClinchFx Ep-Pre -> Marshall 1959 HW with some upgrades -> Suhr RL ->
Matrix Gt1000fx -> Marshall 1960 cab with G12M Blackbacks -> Blend of Sm57 and Sm7 Mics
https://wearepleasantnightmare.bandcamp.com/
- paulscape
The 1st amp is like a distortion box in front of the 2nd amp so extra gain and compression structure are potential benefits. I've only played around with slaving a few times but prefer straight into 1 head with all effects in front, except reverb, that can be added in DAW or FOH.
Eat 'em and smile
NHL Shop Canada
Air Max
Air Jordan 24
Fjallraven
Air Force 1 Women
Jordan 32
Nike Outlet
Jordan retro 14
Jordan 12
Adidas Outlet
Jordan 2s
Pandora Rings Official Site
Dior Jordan
Cheap Jordan Shoes For Men
Rings Pandora
Nike Sneakers
NFL Shop
Adidas Outlet
Pandora Canada
Air Jordan 33
Foamposite
Louboutin Shoes
Nike Wholesale
Men Nike Shoes
Nike Air Force 1
Nike Outlet
Wholesale Nike Air Max
Jordans 6
Jordan 28
Nike Shoes Wholesale
Jordan 16
Pandora
Nike Shoes
What The Jordan 5s
Jordan Concord
Nike AF1
Soccer Jerseys
Jordan 11
Jordan 33 shoes
Nike Acg
Jordan 34
Yeezy Static
Jordan 15
Nike Jordan 1 Mid
Nike Dunk
Nike Shoes
Air Max 270
Huaraches
Jordan 27
Jordans 29
Nike Blazers
Jordan 30
Nike Air Force 1 Low
Kids Jordans
Air Jordan 13 Retro
Pandora Bracelet
Jordan 31
Off White Nike Shoes
Wholesale Jordans
Wholesale Adidas
Wholesale Jerseys
Nike Canada
NMD
Pandora Jewelry
Air Jordan 22
Air Jordan
Nike Women's Shoes
Nike Free Run
Nike Outlet
Wholesale Jordans
Adidas Yeezy Official Website
Adidas Yeezy Boost 350 V2
Nike Air Force
Wholesale Nike Shoes
Wholesale Jordans
Air Force Ones
Nike Air Max 270
Jordans 25
Nike Running Shoes
Nike Blazers
Nike Air Jordan
Nike Cortez
Nike Zoom Pegasus
Nike Cyber Monday
Pandora Charms
Nike Running Shoes
Air Max 97
Nike Huarache
Nike Outlet Store
Cheap Jordans Wholesale
Air Jordan 26
Air Jordan 11 Retro
Jordan 11 Low
Adidas Shoes
Adidas Shoes For Men
Jordan 4
Nike Clearance
NBA Store
Cheap Adidas Shoes
Jordan 35
Nike Canada
Jordan 21
MLB Jerseys
Nike Shoes
New Nike Shoes
Michael Jordan Shoes
Wholesale Jordans From China Factory
Lebron James Sneakers
Wholesale Nike Clothing
Hockey Jerseys
Nike Zoom Pulse
Retro 12
Christian Louboutin
Nike Metcons
Jordans 18
Cheap Jordan Shoes
Jordan Retro
Jordan 33
Nike Air Max 720
Nikes
Nike Wholesale China
Nike Outlet
Jordan 23
Air Jordan Shoes
Jordan AJ 1
Louboutin
Nike React
Official Nike Outlet Online Store
Cheap NBA Jerseys
Nike Shoes For Women
Nike Flip Flops
Pandora Jewelry 70% off Clearance
Jordan 12
Nike Running Shoes For Women
Nike Factory Outlet Store Online
Cheap Womens Nikes
Wholesale Adidas
Nike Air Max Men
Jordans 19
Jordans 13
New Jordans
Air Jordan 1
Nike Shoes
Huarache
Infant Jordans
Nike Outlet
Pandora Jewelry Official Site
Nike
Pandora Jewelry
Nike Wholesale
Jordan 20
Air Jordan 17
Nike Wholesale
Air Max
Air Jordan 24
Fjallraven
Air Force 1 Women
Jordan 32
Nike Outlet
Jordan retro 14
Jordan 12
Adidas Outlet
Jordan 2s
Dior Jordan
Rings Pandora
Nike Sneakers
NFL Shop
Adidas Outlet
Pandora Canada
Air Jordan 33
Foamposite
Louboutin Shoes
Nike Wholesale
Men Nike Shoes
Nike Air Force 1
Nike Outlet
Jordans 6
Jordan 28
Jordan 16
Pandora
Nike Shoes
What The Jordan 5s
Jordan Concord
Nike AF1
Soccer Jerseys
Jordan 11
Jordan 33 shoes
Nike Acg
Jordan 34
Yeezy Static
Jordan 15
Nike Jordan 1 Mid
Nike Dunk
Nike Shoes
Air Max 270
Huaraches
Jordan 27
Jordans 29
Nike Blazers
Jordan 30
Kids Jordans
Air Jordan 13 Retro
Pandora Bracelet
Jordan 31
Wholesale Jordans
Wholesale Adidas
Wholesale Jerseys
Nike Canada
NMD
Pandora Jewelry
Air Jordan 22
Air Jordan
Nike Women's Shoes
Nike Free Run
Nike Outlet
Wholesale Jordans
Nike Air Force
Wholesale Jordans
Air Force Ones
Nike Air Max 270
Jordans 25
Nike Running Shoes
Nike Blazers
Nike Air Jordan
Nike Cortez
Nike Zoom Pegasus
Nike Cyber Monday
Pandora Charms
Nike Running Shoes
Air Max 97
Nike Huarache
Nike Outlet Store
Air Jordan 26
Air Jordan 11 Retro
Jordan 11 Low
Adidas Shoes
Jordan 4
Nike Clearance
NBA Store
Cheap Adidas Shoes
Jordan 35
Nike Canada
Jordan 21
MLB Jerseys
Nike Shoes
New Nike Shoes
Hockey Jerseys
Nike Zoom Pulse
Retro 12
Christian Louboutin
Nike Metcons
Jordans 18
Cheap Jordan Shoes
Jordan Retro
Jordan 33
Nike Air Max 720
Nikes
Nike Outlet
Jordan 23
Air Jordan Shoes
Jordan AJ 1
Louboutin
Nike React
Cheap NBA Jerseys
Nike Flip Flops
Jordan 12
Cheap Womens Nikes
Wholesale Adidas
Nike Air Max Men
Jordans 19
Jordans 13
New Jordans
Air Jordan 1
Nike Shoes
Huarache
Infant Jordans
Nike Outlet
Nike
Pandora Jewelry
Nike Wholesale
Jordan 20
Air Jordan 17
Nike Wholesale
Jordan 11 Win Like 96
NMD
Air Jordan
Jordan 12
Nike Huarache
Air Jordan Shoes
Nike Shoes Outlet
Fitflops
Nike Shoes
Nike Shoes Outlet Store Online Shopping
Pandora Official Site
Pandora
Jordan Retro 11 Mens
Air Jordan 5 Retro
Nike Snkrs
Jordan 4
Jordan Retros
Jordan 11s
Nike Shoes On Sale
Pandora Jewelry
Golden Goose Sneakers Sale
Air Jordan Retro 10
Fjallraven Kanken Backpack
Soccer Shoes
Valentino Sandals
Jordan Retro 9
Cheap Nike Shoes
Jordans 11
Pandora Charms
Golden Goose Sale
Air Jordan Retro
Jordan Retro 12
Air Jordan
Adidas Yeezy
Pandora Charms
Sneakers GGDB
Golden Goose
Moncler Outlet
Nike Air Max 98 Cone
Yeezy
Nike Outlet
Pandora Charms Sale Clearance
Air Jordans
Air Force Ones Shoes
Air Jordan 11
Balenciaga Sneakers
Moncler Outlet
Kyrie Irving Shoes
Pandora Bracelet
Nike Mens Shoes
New Jordan 11
Mid Star Golden Goose
Jordan 5
Air Jordan 3 Retro
Jordan 6
Men Moncler Vest
James Harden shoes
Ferragamo
Adidas NMD R1
Air Jordan 12
Air Jordan 3 Retro
Yeezy
Jordan 1 Retro
Golden Goose Shoes
Jordans Retro
Hermes Birkin
Shoes GGDB
Jordan 13s
Air Max 270
Air Jordan Sneakers
Pandora Jewelry
Jordans Sneakers
Jordan Sneakers
Jordan 11
Jordan Retro 6
Jordan 11 Red
Red Bottom Shoes
Nike Outlet
Nike Official
Nike Factory
Moncler
Air Jordan 11's
Air Jordan 4
Nike Air Max
New Jordans 2021
Air Jordan Retro 8
ECCO Shoes For Men
Nike Air Jordan 5
Moncler Jackets
Pandora Rings
Pandora Ring
James Harden Shoes
Nike Air Max
Louboutin Shoes
Air Jordan 4 Retro
GGDB
Jordan 12 Retro
Jordan Retro
Yeezys
Jordan 11
Ferragamo Outlet Online
Yeezy Shoes
New Nike Shoes
Jordan 6 Rings
New Jordans
Jordan 4
Fitflop Shoes
Moncler
Moncler Outlet
Jordans 11
Red Bottom Shoes
Balenciaga Triple S
Air Jordan 14
Pandora
Jordan Retro 11
Moncler Jackets Outlet
Cheap Jordan Shoes
Jordan Shoes
Red Bottoms Louboutin
Jordan Shoes
Nike Air Max 95
Nike Air Force 1 High
Air Max 90
Golden Goose Outlet
Jordans Sneakers
Moncler
Golden Goose Outlet
Louboutin shoes
Golden Gooses Sneakers
NMD
Air Jordan
Jordan 12
Nike Huarache
Air Jordan Shoes
Nike Shoes Outlet
Fitflops
Nike Shoes
Pandora
Air Jordan 5 Retro
Nike Snkrs
Jordan 4
Jordan Retros
Jordan 11s
Nike Shoes On Sale
Pandora Jewelry
Air Jordan Retro 10
Soccer Shoes
Valentino Sandals
Jordan Retro 9
Cheap Nike Shoes
Jordans 11
Pandora Charms
Golden Goose Sale
Air Jordan Retro
Jordan Retro 12
Air Jordan
Adidas Yeezy
Pandora Charms
Sneakers GGDB
Golden Goose
Moncler Outlet
Yeezy
Nike Outlet
Air Jordans
Air Jordan 11
Balenciaga Sneakers
Moncler Outlet
Kyrie Irving Shoes
Pandora Bracelet
Nike Mens Shoes
New Jordan 11
Jordan 5
Air Jordan 3 Retro
Jordan 6
Men Moncler Vest
James Harden shoes
Ferragamo
Adidas NMD R1
Air Jordan 12
Air Jordan 3 Retro
Yeezy
Jordan 1 Retro
Golden Goose Shoes
Jordans Retro
Hermes Birkin
Shoes GGDB
Jordan 13s
Air Max 270
Air Jordan Sneakers
Pandora Jewelry
Jordans Sneakers
Jordan Sneakers
Jordan 11
Jordan Retro 6
Jordan 11 Red
Red Bottom Shoes
Nike Outlet
Nike Official
Nike Factory
Moncler
Air Jordan 11's
Air Jordan 4
Nike Air Max
New Jordans 2021
Air Jordan Retro 8
ECCO Shoes For Men
Nike Air Jordan 5
Moncler Jackets
Pandora Rings
Pandora Ring
James Harden Shoes
Nike Air Max
Louboutin Shoes
Air Jordan 4 Retro
GGDB
Jordan 12 Retro
Jordan Retro
Yeezys
Jordan 11
Yeezy Shoes
New Nike Shoes
Jordan 6 Rings
New Jordans
Jordan 4
Fitflop Shoes
Moncler
Moncler Outlet
Jordans 11
Red Bottom Shoes
Balenciaga Triple S
Air Jordan 14
Pandora
Jordan Retro 11
Cheap Jordan Shoes
Jordan Shoes
Jordan Shoes
Nike Air Max 95
Air Max 90
Golden Goose Outlet
Jordans Sneakers
Moncler
Golden Goose Outlet
Louboutin shoes
