Stock 68 spec W/2"OT and such...
YMI5150?
Re: Stock 68 spec W/2"OT and such...
Post by YMI5150? » Mon Jun 17, 2013 6:59 pm
well done Phil! :clap: :clap: :thumbsup:
Strat78
Post by Strat78 » Mon Jun 17, 2013 9:46 pm
Thanks for the feedback, but there is so much to try going forward. That was the amp with Chris's PT and the MM OT which I built along side Ben's amp back in 2011. I'm kind of hitting a wall with this amp, I think it might be the MM iron making things a bit too modern sounding. When I get things up and running again I want to work with my other NOS amp with the Marstran irons, the tone was initially a little more woody, but I was having noise problems.
Edit: lacing tutorial from Brian.
http://forum.metroamp.com/viewtopic.php ... g+tutorial" onclick="window.open(this.href);return false;
rgorke
Post by rgorke » Mon Jun 17, 2013 11:17 pm
Strat78 wrote:Almost like a coked out rockabilly tone, but the cool thing about keeping the amp a little on the stiff side, opens a whole world of dynamics via sag and front end push and aggression from the pick. I don't know if you can tell from the clip, but the tones is sweet from top to bottom. Once you introduce an MXR 6B that goes away, so I still can't bring myself to plop some sort of boost after the guitar. The plates were down to 354 with the bias at 2.50 (1.64 was the correct formulated target for biasing without a 1ohm resistor), still, this variac thing is not changing things all that much. Try this: crank your amp and jam away, reach over and turn it off, but continue to play. There is a point where the tone is quite beautiful as the sound fades away. It is articulate yet saggy, crispy, fizzly and warm, that is what I thought the variac should be emulating, but it does not at 90V. Tubes be dammed, next time I'm going to drop the variac even more and see if I can recreate that phenomena.
Based on that discussion in the other part in the forum, I lowered my voltage from about 95v down to 70. It definitely sqished things but a bit too much and I brought it back up to about 80 and that seems to be a bit of a sweet spot....right now.
vanhalen5150
Post by vanhalen5150 » Wed Jun 19, 2013 6:45 am
At 70, what are your heaters showing?
rgorke
Post by rgorke » Fri Jun 21, 2013 2:20 pm
vanhalen5150 wrote:At 70, what are your heaters showing?
Curse you, I just put it back in the cabinet. I brought it back up to 80. I will check.
I am really digging how it sounds. It also cleans up nicely bringing down the volume and the guitar volume.
I can nearly nail this type of tone switching between a MM 1400 and 1300 and the volume pot.
https://www.youtube.com/watch?v=4gDsbOraiqg" onclick="window.open(this.href);return false;
Strat78
Post by Strat78 » Tue Oct 15, 2013 12:00 pm
Been laid up for many months without a knee in my leg, so to keep from going crazy, I have been building away. Here is the latest build which is a kind of tribute to Mark with my own spin. The clip is useless but it was the best I could muster in my condition. Oh, I get a new knee tomorrow so once again I'll be on the wings of opioids....see you all next year. :stars:
larmar2013B.mp3
(1.7 MiB) Downloaded 1506 times
(314.77 KiB) Downloaded 758 times
emmjaydubya
Post by emmjaydubya » Tue Oct 15, 2013 12:31 pm
Wow, sick build!! What's the OT? Sounds great...
Good luck on your knee tomorrow!
Strat78
Post by Strat78 » Tue Oct 15, 2013 1:07 pm
emmjaydubya wrote:Wow, sick build!! What's the OT? Sounds great...
That's one of Chris's 132's that I had in another amp. The heftier OT's are a great match with the 2203/LarMar setup. I've been playing musical OT's lately. The dark brown board looks great with 1w Pihers.
Post by neikeel » Tue Oct 15, 2013 1:11 pm
Yes nice clean build.
Good luck tomorrow ask the 'carpenter' to wash his hands first this time :wink: (says the 'plumber').
Oh and next time ask first and I will dig out some smaller Piher resistors for you!
Strat78
Post by Strat78 » Tue Oct 15, 2013 1:35 pm
neikeel wrote: ask the 'carpenter' to wash his hands first this time :wink: (says the 'plumber').
:lol: I'm in the South now, they'll flush out the wound with Bourbon before sewing me back up, then good to go!
I just wanted to use up those big pihers, but I do have a complete 1/5w set for my jtm 45/100 waiting in the wings, thank you for offering, I still might take you up on it after a while.
YMI5150?
Post by YMI5150? » Tue Oct 15, 2013 2:08 pm
Godspeed tomorrow and speedy recovery. stellar build as usual!
emmjaydubya
Post by emmjaydubya » Tue Oct 15, 2013 3:43 pm
Strat78 wrote:I just wanted to use up those big pihers, but I do have a complete 1/5w set for my jtm 45/100 waiting in the wings, thank you for offering, I still might take you up on it after a while.
You have a Dom block-end chassis, right? PLEASE start a separate step-by step thread on the 45/100 when the time comes, can't wait for that one. I will have to live vicariously through you since I can't afford one of these right now, but I'll bet you end up building my dream amp!
The dark brown board and Pihers on this build hints at a 10,000 or a 45/100... :drool:
efraser68
Post by efraser68 » Tue Oct 15, 2013 8:12 pm
Phil hope you get well soon. Smoking clip dude! What tubes you running in this build?
Post by Tone Slinger » Tue Oct 15, 2013 9:04 pm
Hope everything goes well with your surgery :champ: Love the clip, amps real natural. You brought out great charaecteristics in the 'DTNA' sections :rock:
Strat78
Post by Strat78 » Tue Oct 15, 2013 9:27 pm
Thanks for encouragement! Those are EH 6ca7's and I think a grey plate sylvania for V1.
