I've got some Marshall /Drake transformers (50W) from the early '70's that I want to make a Plexi clone with. I'd also like to add a tube rectifier. Does anybody see a problem with me just adding a 5V tranny inside the chassis (limited space) for the new tube?
Also, does anyone know what the current requirements are of the average 50 and 100 watt Marshall power transformer? Thanks!
Adding tube rectifier
- flemingmras
No there is absolutely no problem with adding a seperate 5 volt tranny for the rectifier heater. However, I believe George also sells a JTM45 power tranny that has a 5 volt winding already in it. But since you already have power trannies, just get a 5V tranny that can supply just enough heater current for the tube rectifier. I'm assuming that you'll be using a 5AR4/GZ34 rec tube, which requires 1.9 amps. So find a 5V 2A trannie and you'll be sittin' pretty.
Also, I believe a 50 watt power tranny needs at least 250mA B+ current while the 100 watter requires one that can supply about 500mA.
Jon
Jon
