Late '67 spec Superbass build (updated w/sounds samples)
Posted: Mon Jan 24, 2022 7:31 am
I've been toying with the idea of building a 10000 series, for quite some time, lots of things happened in between (a 6G16 Vibroverb build, for one), and in the last couple of months I started accumulating the parts.
Basically a late '67 SB with the JTM preamp (single dropping resistor, 470K mixer resistors), low screen filtering, 27K/16Ohm NFB and Drake style iron.
Finally last week, thanks to COVID isolation (and to Heyboer delivering the PT) I had the chance to finish the build.
So, here she is in all her glory:
https://flic.kr/s/aHBqjzzLhv
I used the following:
Metro amp 67-68 steel chassis
Heyboer 1202-132 Metro spec OT
Heyboer 1203-80ML Metro spec PT
ClassicTone 3Hy choke
22/16/50/32 filtering (F&Ts and RIFAs)
SOZO coupling caps
Valvestorm blank perf preamp and power boards with Silver coated Turrets from AliExpress (had to cheap out on something)
Valvestorm front JMP logo panel
Modulus amps Superbass rear panel
Alpha pots - I ditched the Linears for Log (Audio) pots
garden variety 1 Watt Carbon Film resistors, some 1/2 and 1 watt Carbon Comps of different makes (ABs, Xicons...)
Castelco bat switches
Clynder (UK) wire
I deviated from the original spec (if there ever was one) by implementing the Larry grounding scheme, a Lar/Mar PPIMV and a 270pf cap in the tone stack.
In addition, I chose to replace the Linear pots with Logarithmic pots based on George's account of checking old Marshall pots, I have no idea whether the ratios match.
I haven't yet settled on a final V1 cathode cap - I tried 5uf, 220uf and currently using a 10uf BC cap, contemplating trying a 25uf.
Also considering increasing the PI filter cap.
I love the sound - it's organic and very much a cross between the fluidity and bluesy raunch of the JTM45 with the authority and punch of a '68 Superlead - a happy medium I was opting for, having built both the JTM45 and the '68 SL and always wishing for something to bridge the gap between both tonal characteristics.
Would love to hear any input (no pun intended), especially regarding the Linear vs. Log thing and cathode cap value.
SOZO coupling caps
Clynder (UK) wire
