New amp projet: Z-Carbia. UPDATE: CLIPS!
Carbia
Post by Carbia » Wed Jan 15, 2014 7:16 am
Hi guys!
I'm here to introduce you my new build, the Z-Carbia :)
It's something between a DR Z Route66 and a Z28 with some mods/adds by me.
Essentially, it's an EF86 based preamp, with a 12ax7 phase inverter pushing a pair of 6v6's un ultralinear mode on the power stage. All fed by a GZ34 tube rectifier. No NFB and Lar/Mar MV.
I have plugged now a pair of EL34's just to test while I wait to get a nice pair of 6V6's
I used Hammond transformers 372DX on mains power and 1650FA as OT, carbon film resistors, Mallory caps and Alpha pots.
The board is a generic turret board from Tube-town (as all the other stuff) with some turrets added.
Here is the amp chassis:
the back:
Only a few knobs...
And with his cabinet (made at Tube town too)
And now... the PORN:
Hope you like it!
JimiJames
Re: New amp projet: Z-Carbia
Post by JimiJames » Thu Jan 16, 2014 12:35 am
Nice.
No Mid's. O.K.
So, no SS recto... How's the bottom end with that GZ34. Looking forward to a clip.
Build'sClip'sVid's
Carbia
Post by Carbia » Thu Jan 16, 2014 3:50 am
Thank you JimiJames :)
No, no mid's pot, but I have to say that I don't miss it. It works fine with different guitars as a kind of plug and play machine.
The GZ34... is a little bit SS sound. Does not compress or soften so much really. In fact, it's overspec for feeding that circuit that needs less current than a JTM45 for instance.
I have to get a nice pair of 6V6 an then I'll try to record some clips :rock:
Carbia
Post by Carbia » Mon Jan 20, 2014 10:32 am
hey guys!
I've recorded some demo clips of the amp.
Sorry, but I don't have great recording resources. It was recorded with a Shure SM58 and a M-Audio Fast Track.
Full distorted amp (with the master volume turned down to 4)
https://soundcloud.com/josecarbia/z-a-tope" onclick="window.open(this.href);return false;
Half gain.
https://soundcloud.com/josecarbia/z-medio" onclick="window.open(this.href);return false;
The guitar is a '78 Gibson Les Paul Deluxe with the original mini's
Carbia
Re: New amp projet: Z-Carbia. UPDATE: CLIPS!
Post by Carbia » Tue Jan 21, 2014 7:58 am
any opinion? :D
RagnarMarGunn
Post by RagnarMarGunn » Wed Jan 22, 2014 4:14 am
Sounds really good :-)
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
Carbia
Post by Carbia » Wed Jan 22, 2014 7:07 am
People use to say me that sounds in the style of Townsend in "live at Leeds" although I wasn't looking for that song when I built it :lol:
Carbia
Post by Carbia » Mon Feb 17, 2014 3:44 am
New audio clip with better quality :wink:
https://soundcloud.com/josecarbia/carbia" onclick="window.open(this.href);return false;
Carbia
Post by Carbia » Mon Feb 17, 2014 7:29 am
What do you think guys? :wink:
Haze13
Post by Haze13 » Mon Feb 17, 2014 1:49 pm
Sounds Raw! Dirty! As it should be! :hairband:
Haze13
Post by Haze13 » Mon Feb 17, 2014 1:56 pm
UltraLinear... Is it a Class A Push-Pull power amp?
How much of the PPIMV do you use?
I set mine on the JCM800 on 2-3 o'clock, so it's attenuate not that much. Still the amp is a tinny bit fizzy, but it's much better than it was.
Carbia
Post by Carbia » Mon Feb 17, 2014 5:36 pm
It's a regular AB push-pull, but with the screen grids feed by a tap on the OT's secondary.
Basically, like this, but fixed bias, not cathode bias as the picture shows:
The Master volume was around 4 over 10 during the recording, but it works much better in this amp than in PLexis or 800's due to this amp doesn't have negative feedback, so doesn't sound fizzy at low master settings.
Thank your for comment :rock:
Haze13
Post by Haze13 » Tue Feb 18, 2014 10:44 am
Thanks for the info!
I see a wire soldered on the backs of the pots. I had to remove mine to get rid of a radio interference... It creates several ground loops (At least in my build), so I was wondering, do you have some strange noises like RF on the louder settings?
Carbia
Post by Carbia » Tue Feb 18, 2014 12:22 pm
No, mine is totally quiet.
All the grounds from the board goes to the ground buss bar on the pots. And then to a ground point in one of the PT screws, among the ground from electrolitics of the power supply.
The only ground that don't go to that point is the cathode os the power tubes, that it's on their own socket screw.
Am_I_Evil
Post by Am_I_Evil » Fri Feb 21, 2014 1:33 am
Nice :), is this similar to trainwreck amps?
