Amp BIAS issue? HELP PLEASE!
Hi guys so after a week of playing my newest build I thought I'd check voltages etc.
Heaters are 3.3 volts per side so 6.6-6.7, a bit high but should be ok.
Preamp voltages on the cathodes are about 10% lower than George's kit chart, and the plates are around 1 (meant to be 2?)
The Issue is when I bias the amp.
V4 reads 0.040 volts DC
V5 reads 0.040
V6 reads 29 volts ???????????????????????????????????????
V7 reads 0.036
Also I had to turn the ppimv right down to stop a crazy hum noise etc coming through the speakers as I biased it.
Finally thats as low as I can bias it, should they all be around 37ish? If so what do I need to change on the bias circuit to give me that range?
Any help would be much appreciated, no idea why v6 bias is so all over the place??
V5 reads 0.040
V7 reads 0.036
Re: Amp BIAS issue? HELP PLEASE!
So I swapped v6 and v7 tubes around to see if it was a tube, apparently the tubes are fine, assuming its something to do with that socket wiring / components?
Ok so I think I fixed my own problem. The 1ohm resistor going to ground was stuffed. I replaced it and all seems normal.
Bias voltages range from 0.035 - 0.039
So I'm assuming thats where I want it
So new problem the amp is making a weird humming noise and when i play a guitar through it its making a strange motor boating sound and sounds like it has some sort of weird envelope filter on it or something?
One thing to note is on V4 I accidently touched something with the multimeter probe whilst biasing and it had a bang and sparks etc, Could I have blown something on the board?
Power or preamp?
Typically power amp if you had sparks whilst biasing.PeterJ_22 wrote:Power or preamp?
Preamp tubes (V1 or V2) usually whistle or crackle a duff PI tube can give imbalance with hum and motorboating but so can a failed mains or screens filter can.
Thanks for the response.
Is there any way to test what might be wrong before I go and order new parts?
Ok so luckily for me I just tried another phase inverter tube and all is well!!!!
Glad I did that as I was about to order another set of EL34s!
Thanks again for the help
