Hi, i'm just starting a JCM800 2204 build and i'm looking at buying parts quick - i'm heading to the states for wedding and given that to buy the parts at home involves importing from the states i figure ill save some money and buy while im there. Anyway, i leave this afternoon so on a tight schedule!
I've got a few questions but the most important are the big items (much cheaper to ship smaller items if i don't have time to buy in the states).
TRANSFORMERS
I've decided to go with Classic Tone transformers.
OT - # 40-18025
Choke - # 40-18032
For the PT i've got the options at Classic Tone for either of these:
- # 40-18023
- # 40-18095
the second one is their upgraded PT. They say this about it:
"This also is a great upgrade power transformer since it features the highest performing and coolest running, grain oriented M-6 steel lamination, a copper flux band for hum reduction and three separate B+ rating options appropriate for a variety of solid state and tube rectification applications. This is a very versatile Marshall style power transformer for use in 50W or "so" DIY amp projects and new OEM builds."
It's 27 bucks more and i don't want to pay for anything that doesn't increase reliability or tone. What do you guys think i should get?
Thanks,
Tim
2204 build from scratch. Help needed with transformers.
Re: 2204 build from scratch. Help needed with transformers.
With the upgrade, you get two different voltage options. Depending on wall voltage you can get approx 420-25 on the plates or 470-75 with SS rectification. If you want only the higher voltage, the standard will fit the bill.
Thanks for the info. What might be the benefits of having the option of a lower plate voltage?OnTheFritz wrote:With the upgrade, you get two different voltage options. Depending on wall voltage you can get approx 420-25 on the plates or 470-75 with SS rectification. If you want only the higher voltage, the standard will fit the bill.
- demonufo
The lower voltage will get you closer to that late 70's 2204 tone, with more compression.
The higher voltage may find you running an extra resistor to drop the B+ to the power tubes in order to get it sounding as sweet.
So I like purple, okay!!!!!!
- syscokid
PM sent...theFan wrote: I've decided to go with Classic Tone transformers.
OT - # 40-18025
