demonufo wrote:I was just thinking it's a shame about the gold plating.
I started to use a steel brush in my Dremel tool to take the gold off and it had some kind of reaction with the gold. Like a galvanic process of some kind or something. I tried to search for info, but you put steel and gold in a search and what mostly seemed to come up were advertisements for jewelry. It was strange, though, 'cause as soon as I started using the brush the white ceramic of the socket turned black. Like some kind of carbon deposit or something. I cleaned off the ceramic with a tub and tile cleaner called, "The Works" that's based on phosphoric acid and it cleaned up pretty fast.
BTW, just to digress for a second..."The Works" is great stuff, but the original phosphoric acid formula is apparently not working out well for consumers who need warnings not to use it to rinse out their eyes and nose or whatever, so now I'm seeing it pop up in formulas that use very dilute hydrochloric acid and most recently a mixture of oxalic acid and glycolic acid that's almost useless against really nasty stuff. I wish we could have a high shelf in hardware stores with chemicals for adults who passed basic chemistry and understand the dangers involved in using these things so we don't all have to end up using citrus-based cleaners for things that would move faster with a little mad science-y motivation.
Anyway, I actually ended up using sulfuric acid ("One-Shot" drain cleaner) to burn off the gold on the pins and then neutralized it with baking soda and water. Worked fine.
However, I kinda wonder if just using enough flux might do the job just as well. The gold plating is very thin.
-Rob
