I'm planning to build my own 'signature amp' that combines the full roar of a Super Bass with the sting of the Caswell/Levi mod (I'm not aiming for a 100% AFD sound. It has to suit my ears and hands, not Slash's).
Transformers: PT Marstran Dagnall T2562, choke Marstran C1999, OT Metroamp C1998
Filtering
Mains 50 (2x 100uF)
Screens 33uF (4x Rifa 33uF)
PI 33uF
CF 33uF
Superbass 'V1' 22uF
2203 'V1' 33uF
#36/#39 stage 22uF
This amp has 5 preamp tubes, because I want to keep the shared cathode thing, I like that.
Well, the plan behind this preamp is that I can use the hot rodded 2203 stage and the Plexi stage at once, when linked together.
The normal channel of the Super Bass preamp is 'buried' (so the grid goes with a 33K to ground, like unplugged).
the volume knob of the normal channel is on the board and is for fine tuning the amount of bass.
In place of the normal channel there's the gain knob for the modded 2203 section.
The mixer resistors all go to a switch where I can chose the Plexi channel only, Plexi + Hot Rod 2203, or only 2203.
Another feature is a switchable master volume (which is on top of the chassis for shortest possible wire lenghts and tro keep the 6 knob 4-holer look of the amp.
For detail just look at the layout.
I want to introduce the Larry grounding scheme, but I dunno how it will work with 2 different stages in parallel. maybe somebody can jump in and give some advise.
Also if the high tension rail of the preamp is done right for implementing the Larry grounding.
Thanks for any advise in advance!
Cheers
Dom
